path: root/include/configs/espt.h
2018-01-15net: sh-eth: Add to Kconfig and convertNobuhiro Iwamatsu
This adds SH_ETHER to drivers/net/Kconfig and convert to Kconfig. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-01-10sh: Drop unreferenced CONFIG_* definesTuomas Tynkkynen
The following config symbols are only defined once and never referenced anywhere else: CONFIG_AP325RXA CONFIG_AP_SH4A_4A CONFIG_CPU_SH_TYPE_R CONFIG_ECOVEC CONFIG_ESPT CONFIG_MIGO_R CONFIG_MPR2 CONFIG_MS7720SE CONFIG_MS7722SE CONFIG_MS7750SE CONFIG_R0P7734 CONFIG_R2DPLUS CONFIG_RSK7203 CONFIG_RSK7264 CONFIG_RSK7269 CONFIG_SH7752EVB CONFIG_SH7753EVB CONFIG_SH7757LCR CONFIG_SH7763RDP CONFIG_SH7785LCR Most of them are config symbols named after the respective boards which seems to have been a standard practice at some point. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2017-09-03include/configs: remove default values of CONFIG_SYS_BARGSIZEThomas Petazzoni
CONFIG_SYS_BARGSIZE is already defined to 512 in common/image.c when not defined. Therefore, there is no point in having board configuration files define it to 512. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11Convert CONFIG_CMD_SDRAM to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SDRAM Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-03serial: sh: Convert to KconfigMarek Vasut
Convert the SH Serial to Kconfig using tools/moveconfig.py tool and a bit of manual adjustment to cater for failed conversions. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22Kconfig: Drop CONFIG_CMD_ENVSimon Glass
This option is not used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-12-02sh: define CONFIG_DISPLAY_BOARDINFO to print board informationVladimir Zapolskiy
All SH boards define a checkboard() function which outputs basic board information on boot, however generic board support requires to define CONFIG_DISPLAY_BOARDINFO to do that, so define it for the boards. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2014-01-08sh: sh4: remove CONFIG_SH4 definition from board configNobuhiro Iwamatsu
CONFIG_SH4 was already defined in arch/sh/sh4/config.mk. This removes CONFIG_SH4 from board config files of SH4. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-08sh: delete redundant CONFIG_SH definitionMasahiro Yamada
CONFIG_SH is defined in arch/sh/config.mk. It is not necessary to define it in each board header config header file. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-17sh: boards: Change clock definition of SCIF and TMUNobuhiro Iwamatsu
This changes clock definition of SCIF from CONFIG_SYS_CLK_FREQ to CONFIG_SH_SCIF_CLK_FREQ, and clock definition of TMU from CONFIG_SYS_CLK_FREQ to CONFIG_SH_TMU_CLK_FREQ for boards. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2012-05-28sh: Set CONFIG_SH_ETHER_PHY_MODE and CONFIG_SH_ETHER_SH7734_MII to boards ↵Nobuhiro Iwamatsu
with sh_eth The board with sh_eth needs to set CONFIG_SH_ETHER_PHY_MODE. And SH7734 needs to set value of CONFIG_SH_ETHER_SH7734_MII. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-12-02sh: espt: change config for new sh_eth driverYoshihiro Shimoda
The new sh_eth driver uses the phy driver. So, this patch enables it. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2011-02-02sh: Remove config.mk for espt boardNobuhiro Iwamatsu
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the unnecessary config.mk file. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-11sh: Add support ESPT-GIGA boradNobuhiro Iwamatsu
ESPT-Giga is SH7763-based reference board. Board support is relatively sparse, presently supporting serial, gigabit ethernet, USB host, and MTD. More information (in Japanese) available at: http://www.cente.jp/product/cente_hard/ESPT-Giga.html Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
