path: root/include/configs/ep8248.h
2008-02-12Get rid of "#undef DEBUG" from board config files.Wolfgang Denk
2007-07-10include/configs/[a-e]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-09include/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
Mostly removed from comments here. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-05include/configs: Use new CONFIG_CMD_* in various e* named board config files.Jon Loeliger
2005-08-06Add support for ep8248 boardWolfgang Denk
Patch by Yuli Barcohen, 12 Dec 2004 Minor code cleanup.
