path: root/include/configs/enbw_cmc.h
2014-11-20ARM: remove CONFIG_ARM926EJS definesMasahiro Yamada
CONFIG_CPU_ARM926EJS was introduced into Kconfig by commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs). This commit removes all the defines of CONFIG_ARM926EJS and replaces the only reference in arch/arm/lib/cache.c with CONFIG_CPU_ARM926EJS. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-17i2c, davinci: convert driver to new mutlibus/mutliadapter frameworkVitaly Andrianov
- add davinci driver to new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Acked-by: Heiko Schocher <hs@denx.de>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-08-19configs: Remove unused CONFIG_BOOTP_DEFAULTTom Rini
2013-05-10davinci: handle CONFIG_SYS_CLE_MASK and CONFIG_SYS_ALE_MASKEric Benard
these variables are curently defined in several config files but the driver doesn't use them and defaults to hardcoded values in nand_defs.h It's interesting to be able to change this hardcoded valude when the hardware is not using the default adress signals to drive ALE and CLE and two configuration defines already exist for this purpose so use them. Signed-off-by: Eric BĂ©nard <eric@eukrea.com>
2012-10-15COMMON: Use __stringify() instead of xstr()Marek Vasut
Kill multiple occurances and redeclaration of xstr in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01Consolidate bootcount code into drivers/bootcountStefan Roese
This patch moves all bootcount implementations into a common directory: drivers/bootcount. The generic bootcount driver is now usable not only by powerpc platforms, but others as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Manfred Rudigier <manfred.rudigier@omicron.at> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Reinhard Meyer <reinhard.meyer@emk-elektronik.de> Tested-by: Valentin Longchamp <valentin.longchamp@keymile.com> Tested-by: Christian Riesch <christian.riesch@omicron.at> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-07-07arm,davinci: update for enbw_cmc boardHeiko Schocher
- change gpio pin settings: - gpio pin 6[13] (PLC reset) default value low - gpio pin 6[0] (TPM reset) default value low - 4 new GPIO pins pin i/o name - 3[9] input Board Type - 2[7] input HW-ID0 - 2[6] input HW-ID1 - 2[3] input HW-ID2 - read board type and hw id from gpio pins on the enbw_cmc board, and use board type for setting up different gpio pin settings. - do not pass "davinci_mmc.use_dma=0" to linux, as MMC now works with DMA. - update logbuf support: store post word in RTC scratch register - add support for configuring KSZ8864RMN switch through a config file on u-boot startup. For more infos see: doc/README.switch_config Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <tom.rini@gmail.com> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Sandeep Paulraj <s-paulraj@ti.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-02-12Changes to move hawkboard to the new spl infrastructureSughosh Ganu
This patch moves hawkboard to the new spl infrastructure from the older nand_spl one. Removed the hawkboard_nand_config build option -- The spl code now gets compiled with hawkboard_config, after building the main u-boot image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard to reflect the same. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Tom Rini <trini@ti.com> Acked-by: Christian Riesch <christian.riesch@omicron.at>
2012-02-12arm, arm926ejs: Add option CONFIG_SYS_EXCEPTION_VECTORS_HIGHChristian Riesch
The V bit of the c1 register of CP15 should not be cleared on DA850 SoCs since they have no valid memory at 0x00000000. This patch introduces a configuration option CONFIG_SYS_EXCEPTION_VECTORS_HIGH that allows setting the correct value for the V bit. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Reported-by: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Heiko Schocher <hs@denx.de>
2012-02-12arm, arm926ejs: Do cpu critical inits only for boards that require itChristian Riesch
This patch reverts commit ca4b55800ed74207c35271bf7335a092d4955416 "arm, arm926ejs: always do cpu critical inits" since it impacts all arm926ejs based configurations and caused problems, e.g., with the hawkboard. Instead the patch removes the CONFIG_SKIP_LOWLEVEL_INIT defines from the board configurations that need low level initialization. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de> Tested-by: Heiko Schocher <hs@denx.de>
2012-02-12davinci: add support for printing clock frequencyHadli, Manjunath
add support for printing various clock frequency info found in SOC such as ARM core frequency, DSP core frequency and DDR frequency as part of bdinfo command. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com>
2012-02-12davinci: remove macro CONFIG_DISPLAY_CPUINFOHadli, Manjunath
remove the macro CONFIG_DISPLAY_CPUINFO as it is no longer required. This is because clock info will be printed as part 'bdinfo' command and also remove support print_cpuinfo() as it will no longer be called. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com>
2012-02-12configs: Remove CONFIG_NET_MULTI from board filesFabio Estevam
CONFIG_NET_MULTI is not used anymore, so remove it from board files. Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Kumar Gala <kumar.gala@freescale.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefano Babic <sbabic@denx.de> Tested-by: Marek Vasut <marek.vasut@gmail.com> Tested-by: Heiko Schocher <hs@denx.de>
2012-01-26NAND: Remove additional (CONFIG_SYS)_NAND_MAX_CHIPSScott Wood
NAND_MAX_CHIPS has been replaced by CONFIG_SYS_NAND_MAX_CHIPS, and the latter defaults to 1. Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-12-06arm, davinci: add support for am1808 based enbw_cmc boardHeiko Schocher
- booting from NOR Flash with direct boot method - POST support - LOGBUF support Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Paulraj Sandeep <s-paulraj@ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Christian Riesch <christian.riesch@omicron.at>
