path: root/include/configs/edminiv2.h
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2011-04-27Replace obsolete e-mail addressAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2010-10-13edminiv2: add support for ELF relocationsAlbert Aribaud
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-08-30edminiv2: add I2C support using mvtwsi driverAlbert Aribaud
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar<prafulla@marvell.com> Acked-by: Heiko Schocher<hs@denx.de>
2010-08-08edminiv2: add mvsata_ide and cmd_ide supportAlbert Aribaud
Add mvsata_ide and cmd_ide configuration in edminiv2 config Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-07-12edminiv2: add ethernet supportAlbert Aribaud
Add edminiv2 board support for mv_egiga. Add edminiv2 config to enable mv_egiga. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-06-17Add support for the LaCie ED Mini V2 boardAlbert Aribaud
This patch adds support for the LaCie ED Mini V2 product which is based on the Marvell Orion5x SoC. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
