path: root/include/configs/ecovec.h
2018-09-15sh: tmu: Clean up CONFIG_SH_TMU_CLK_FREQMarek Vasut
The R-Car Gen2 feeds the TMU with CONFIG_SYS_CLK_FREQ / 2, while the old SH parts use CONFIG_SYS_CLK_FREQ directly. Just put this into the TMU implementation and drop the CONFIG_SH_TMU_CLK_FREQ config option. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-09-15sh: tmu: Clean up CONFIG_SYS_TMU_CLK_DIVMarek Vasut
This constant is always 4 , for all boards that exist. Define it once in arch/sh/lib/time.c and remove it from the configs. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-04-08treewide: Migrate CONFIG_SYS_ALT_MEMTEST to KconfigMario Six
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration after also including CMD_MEMTEST] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-15net: sh-eth: Add to Kconfig and convertNobuhiro Iwamatsu
This adds SH_ETHER to drivers/net/Kconfig and convert to Kconfig. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-01-10sh: Drop unreferenced CONFIG_* definesTuomas Tynkkynen
The following config symbols are only defined once and never referenced anywhere else: CONFIG_AP325RXA CONFIG_AP_SH4A_4A CONFIG_CPU_SH_TYPE_R CONFIG_ECOVEC CONFIG_ESPT CONFIG_MIGO_R CONFIG_MPR2 CONFIG_MS7720SE CONFIG_MS7722SE CONFIG_MS7750SE CONFIG_R0P7734 CONFIG_R2DPLUS CONFIG_RSK7203 CONFIG_RSK7264 CONFIG_RSK7269 CONFIG_SH7752EVB CONFIG_SH7753EVB CONFIG_SH7757LCR CONFIG_SH7763RDP CONFIG_SH7785LCR Most of them are config symbols named after the respective boards which seems to have been a standard practice at some point. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2017-09-03include/configs: remove default values of CONFIG_SYS_BARGSIZEThomas Petazzoni
CONFIG_SYS_BARGSIZE is already defined to 512 in common/image.c when not defined. Therefore, there is no point in having board configuration files define it to 512. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11Convert CONFIG_CMD_SDRAM to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SDRAM Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-03serial: sh: Convert to KconfigMarek Vasut
Convert the SH Serial to Kconfig using tools/moveconfig.py tool and a bit of manual adjustment to cater for failed conversions. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22Kconfig: Drop CONFIG_CMD_ENVSimon Glass
This option is not used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-12-02sh: define CONFIG_DISPLAY_BOARDINFO to print board informationVladimir Zapolskiy
All SH boards define a checkboard() function which outputs basic board information on boot, however generic board support requires to define CONFIG_DISPLAY_BOARDINFO to do that, so define it for the boards. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh: remove undefined DEBUG preprocessor token from board config filesVladimir Zapolskiy
By default this undef is a noop, moreover at this point when the platform support is broken is prevents debugging of U-boot by manual insertion of #define DEBUG into common files, so it makes sense to remove the option from all SH boards as a harmful one. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-23Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_ENV_OVERWRITE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_ENV_OVERWRITE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2014-02-19configs: Delete obsolete macro, CONFIG_SYS_GBL_DATA_SIZEMasahiro Yamada
CONFIG_SYS_GBL_DATA_SIZE is not used any more. The size of struct "global_data" is automatically calculated by asm-offsets. (See lib/asm-offsets.c) GENERATED_GBL_DATA_SIZE should be used instead of CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-09sh: sh4: Remove CONFIG_SH4A definition from source codeNobuhiro Iwamatsu
SH4 and SH4A are compatible. But some instructions are different from these. In Linux kernel, It is treated as a separate CPU, but for now, I think that there is no need to divide especially in the U-Boot. This removes CONFIG_SH4A definition from source code, SH4A is treated as SH4. And this fix white space. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-08sh: sh4: remove CONFIG_SH4 definition from board configNobuhiro Iwamatsu
CONFIG_SH4 was already defined in arch/sh/sh4/config.mk. This removes CONFIG_SH4 from board config files of SH4. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-08sh: delete redundant CONFIG_SH definitionMasahiro Yamada
CONFIG_SH is defined in arch/sh/config.mk. It is not necessary to define it in each board header config header file. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-11-13i2c: sh_i2c: Update to new CONFIG_SYS_I2C frameworkNobuhiro Iwamatsu
This updates to new I2C framwwork on sh_i2c. And this also updates boards(kzm9g and ecovec) that using sh_i2c. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-17sh: boards: Change clock definition of SCIF and TMUNobuhiro Iwamatsu
This changes clock definition of SCIF from CONFIG_SYS_CLK_FREQ to CONFIG_SH_SCIF_CLK_FREQ, and clock definition of TMU from CONFIG_SYS_CLK_FREQ to CONFIG_SH_TMU_CLK_FREQ for boards. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2012-05-28sh: Set CONFIG_SH_ETHER_PHY_MODE and CONFIG_SH_ETHER_SH7734_MII to boards ↵Nobuhiro Iwamatsu
with sh_eth The board with sh_eth needs to set CONFIG_SH_ETHER_PHY_MODE. And SH7734 needs to set value of CONFIG_SH_ETHER_SH7734_MII. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-04-18sh: ecovec: Change macro from BOARD_LATE_INIT to CONFIG_BOARD_LATE_INITNobuhiro Iwamatsu
When calling board_late_init, we need to define CONFIG_BOARD_LATE_INIT. The latest ecovec config defines BOARD_LATE_INIT, board_late_init is not called. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-03-08sh: ecovec: Add support PHY of SMSCNobuhiro Iwamatsu
2012-02-12configs: Remove CONFIG_NET_MULTI from board filesFabio Estevam
CONFIG_NET_MULTI is not used anymore, so remove it from board files. Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Kumar Gala <kumar.gala@freescale.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefano Babic <sbabic@denx.de> Tested-by: Marek Vasut <marek.vasut@gmail.com> Tested-by: Heiko Schocher <hs@denx.de>
2011-12-02sh: Add support for ecovec boardNobuhiro Iwamatsu
The ecovec board has SH7724, 256MB DDR2-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - 256MB DDR2-SDRAM - USB - I2C - Ethernet Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
