path: root/include/configs/eb_cpux9k2.h
2012-11-04arm: atmel: cpux9k2: add missing cache configsJens Scharsig (BuS Elektronik)
* add CONFIG_SYS_CACHELINE_SIZE to eb_cpux9k2 board config header * dissable dcache (CONFIG_SYS_DCACHE_OFF) for eb_cpux9k2 Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
2012-09-04atmel: eb_cpux9k2: add ram target configurationJens Scharsig
* add ram target for EB+CPUx9k2 board (eb_cpux9k2_ram_config) Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-05-15include/configs: Remove CONFIG_SYS_64BIT_VSPRINTFTom Rini
This define does not control anything, remove it. Signed-off-by: Tom Rini <trini@ti.com>
2012-04-21eb_cpux9k2: add USB host support to boardJens Scharsig
2012-01-26NAND: Remove additional (CONFIG_SYS)_NAND_MAX_CHIPSScott Wood
NAND_MAX_CHIPS has been replaced by CONFIG_SYS_NAND_MAX_CHIPS, and the latter defaults to 1. Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-11-05Arm: re-introduce the MACH_TYPE_XXXXXX for EB_CPUX9K2 boardJens Scharsig
* re-introduce the MACH_TYPE_XXXXXX for EB_CPUX9K2 board Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2011-07-04eb_cpux9k2: use atmel_usartAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Jens Scharsig <js_at_ng@scharsoft.de> Acked-by: Jens Scharsig<js_at_ng@scharsoft.de> Tested-by: Jens Scharsig<js_at_ng@scharsoft.de> (for eb_cpux9k2 board)
2011-07-04arm920t/at91: use new clock.c featuresAndreas Bießmann
This patch enables the new clock features from arm920t/at91/clock.c. This is an required step to get at91rm9200_usart replaced by atmel_usart driver. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Jens Scharsig <js_at_ng@scharsoft.de> Cc: Eric Bénard <eric@eukrea.com>
2011-06-21update arm/at91rm9200 work with rework rework110202Jens Scharsig
* convert at91rm9200ek and eb_cpux9k2 board to ATMEL_xxx name scheme * Fix: timer.c compile error io.h not found with arm/at91rm9200 * update arm920t/at91 to ATMEL_xxx name scheme * update arm920t/at91 soc lib * update at91_emac driver Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Tested-by: Andreas Bießmann <andreas.devel@gmail.com>
2010-10-19update board EB+CPUx9K2Jens Scharsig
* update to support arm reloaction * unnecessary environment variables removed Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-02-12new board (eb_cpux9k2)Jens Scharsig
* new board (eb_cpux9k2) * support for EB+CPUx9K2 board by BuS Elektronik GmbH & Co. KG * select via make eb_cpux9k2_config * this also demonstrates, how to use boards with AT91RM9200 cpu in at91 arch tree Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
