path: root/include/configs/eb_cpux9k2.h
2012-01-26NAND: Remove additional (CONFIG_SYS)_NAND_MAX_CHIPSScott Wood
NAND_MAX_CHIPS has been replaced by CONFIG_SYS_NAND_MAX_CHIPS, and the latter defaults to 1. Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-11-05Arm: re-introduce the MACH_TYPE_XXXXXX for EB_CPUX9K2 boardJens Scharsig
* re-introduce the MACH_TYPE_XXXXXX for EB_CPUX9K2 board Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2011-07-04eb_cpux9k2: use atmel_usartAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Jens Scharsig <js_at_ng@scharsoft.de> Acked-by: Jens Scharsig<js_at_ng@scharsoft.de> Tested-by: Jens Scharsig<js_at_ng@scharsoft.de> (for eb_cpux9k2 board)
2011-07-04arm920t/at91: use new clock.c featuresAndreas Bießmann
This patch enables the new clock features from arm920t/at91/clock.c. This is an required step to get at91rm9200_usart replaced by atmel_usart driver. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Jens Scharsig <js_at_ng@scharsoft.de> Cc: Eric Bénard <eric@eukrea.com>
2011-06-21update arm/at91rm9200 work with rework rework110202Jens Scharsig
* convert at91rm9200ek and eb_cpux9k2 board to ATMEL_xxx name scheme * Fix: timer.c compile error io.h not found with arm/at91rm9200 * update arm920t/at91 to ATMEL_xxx name scheme * update arm920t/at91 soc lib * update at91_emac driver Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Tested-by: Andreas Bießmann <andreas.devel@gmail.com>
2010-10-19update board EB+CPUx9K2Jens Scharsig
* update to support arm reloaction * unnecessary environment variables removed Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-02-12new board (eb_cpux9k2)Jens Scharsig
* new board (eb_cpux9k2) * support for EB+CPUx9K2 board by BuS Elektronik GmbH & Co. KG * select via make eb_cpux9k2_config * this also demonstrates, how to use boards with AT91RM9200 cpu in at91 arch tree Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
