path: root/include/configs/ea20.h
2013-08-19configs: Remove unused CONFIG_BOOTP_DEFAULTTom Rini
2013-03-11Merge u-boot/master into u-boot-ti/masterTom Rini
In master we had already taken a patch to fix the davinci GPIO code for CONFIG_SOC_DM646X and in u-boot-ti we have additional patches to support DA830 (which is CONFIG_SOC_DA8XX && !CONFIG_SOC_DA850). Resolve these conflicts manually and comment the #else/#endif lines for clarity. Conflicts: arch/arm/include/asm/arch-davinci/gpio.h drivers/gpio/da8xx_gpio.c Signed-off-by: Tom Rini <trini@ti.com>
2013-03-04ubifs: Allow ubifsmount volume reference by numberJoe Hershberger
UBI can mount volumes by name or number The current code forces you to name the volume by prepending every name with "ubi:". >From fs/ubifs/super.c * There are several ways to specify UBI volumes when mounting UBIFS: * o ubiX_Y - UBI device number X, volume Y; * o ubiY - UBI device number 0, volume Y; * o ubiX:NAME - mount UBI device X, volume with name NAME; * o ubi:NAME - mount UBI device 0, volume with name NAME. Now any name passed in any of the above forms are allowed. Also update the configs that referenced ubifsmount. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-02-18da8xx: ea20: Add the configuration define for the exact SoC variantTomas Novotny
Signed-off-by: Tomas Novotny <tomas@novotny.cz> Cc: Tom Rini <trini@ti.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-10-15COMMON: Use __stringify() instead of xstr()Marek Vasut
Kill multiple occurances and redeclaration of xstr in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-10-01davinci: ea20: add some configs and default environmet variablesBastian Ruppert
Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: Tom Rini <trini@ti.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-10-01davinci: ea20: the console is always set to the serial lineBastian Ruppert
Do not allow to overwrite it when video is enabled. Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: Tom Rini <trini@ti.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-05-15arm: ea20: Change macro from BOARD_LATE_INIT to CONFIG_BOARD_LATE_INITNobuhiro Iwamatsu
With almost all the architecture and board BOARD_LATE_INIT does not use. CONFIG_BOARD_LATE_INIT is used instead. This changed CONFIG_BOARD_LATE_INIT from BOARD_LATE_INIT. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-05-15include/configs: Remove CONFIG_SYS_64BIT_VSPRINTFTom Rini
This define does not control anything, remove it. Signed-off-by: Tom Rini <trini@ti.com>
2012-03-27Davinci: ea20: use gpio framework to access gpiosStefano Babic
Drop direct access to SOC's registers and use the function of the GPIO driver for da8xx. [Tom: Remove gpio[68]_base as it's now unused] Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: dzu@denx.de CC: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-02-12davinci: add support for printing clock frequencyHadli, Manjunath
add support for printing various clock frequency info found in SOC such as ARM core frequency, DSP core frequency and DDR frequency as part of bdinfo command. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com>
2012-01-26NAND: remove NAND_MAX_CHIPS definitionsVladimir Zapolskiy
This change follows the change by Wolfgang Grandegger (commit 6c869637fef), which allows to remove useless NAND_MAX_CHIPS definitions in board config files. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-11-03Davinci: ea20: added PREBOOT to configurationStefano Babic
PREBOOT is used on the ea20 to load a splash image at the start up. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03Davinci: ea20: added I2C supportStefano Babic
2011-11-03Davinci: ea20: added video supportStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> Cc: Anatolij Gustschin <agust@denx.de> CC: Sandeep Paulraj <s-paulraj@ti.com> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03Davinci: ea20: add gpio for keeping power on in board_late_initBastian Ruppert
The pin called HALTEN drives a transistor to operate the supply voltage. After HALTEN is high, the user can release the power switch button and the device will stay powered on. Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: sbabic@denx.de CC: dzu@denx.de Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03Davinci: ea20: Add default U-Boot environmentStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03Davinci: ea20: Add NAND supportStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Sandeep Paulraj <s-paulraj@ti.com> CC: Scott Wood <scottwood@freescale.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03Davinci: ea20: set console on UART0Bastian Ruppert
Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUMManjunath Hadli
remove macro CONFIG_EMAC_MDIO_PHY_NUM and depending macro EMAC_MDIO_PHY_NUM as they are no longer needed with the support for more than 1 PHYs in davinci emac driver. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-30Davinci: add support for the ea20 boardStefano Babic
This board uses the OMAP-L138 SOM stacked on a custom baseboard. It supports SPI Flash, Ethernet with RMII. Signed-off-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
