path: root/include/configs/eNET.h
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-05-06eNET: Implement eNET WatchdogGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2010-05-06eNET: Use SC520 MMCR to reset eNET boardGraeme Russ
2010-05-06eNET: Add support for onboard RTL8100B (RTL8139) chipsGraeme Russ
2010-05-06eNET: Fix CONFIG_SYS_HZ to be 1000Graeme Russ
The clock interupt has always been 1kHz as per timer_init() in /arch/i386/cpu/sc520/sc520_timer.c Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2010-05-06eNET: Fix Flash WriteGraeme Russ
Onboard AMD Flash chip does not support buffered writes Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2010-05-06x86: Use CONFIG_SERIAL_MULTIGraeme Russ
2009-12-05i386: Final RelocationGraeme Russ
2009-12-05i386: Fix global label in inline asm compile errorGraeme Russ
2009-12-05i386: Fix malloc initializationGraeme Russ
2009-09-04Add PCI support to eNET boardGraeme Russ
2009-09-04Fix environment configuration for eNET boardGraeme Russ
The current configuration of the Environment has the redundant copy of the environment in the Boot Flash - This was never the intent. The Environment should instead be in the first two sectors of the first Strata Flash Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-29Remove nowhere used symbol CONFIG_SYS_CLKS_IN_HZLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2009-03-20Rewrite i386 interrupt handlingGraeme Russ
Rewrite interrupt handling functionality for the i386 port. Separated functionality into separate CPU and Architecture components. It appears as if the i386 interrupt handler functionality was intended to allow multiple handlers to be installed for a given interrupt. Unfortunately, this functionality was not fully implemented and also had the problem that irq_free_handler() does not allow the passing of the handler function pointer and therefore could never be used to free specific handlers that had been installed for a given IRQ. There were also various issues with array bounds not being fully tested. I had two objectives in mind for the new implementation: 1) Keep the implementation as similar as possible to existing implementations. To that end, I have used the leon2/3 implementations as the reference 2) Seperate CPU and Architecture specific elements. All specific i386 interrupt functionality is now in cpu/i386/ with the high level API and architecture specific code in lib_i386. Functionality specific to the PC/AT architecture (i.e. cascaded i8259 PICs) has been further split out into an individual file to allow for the implementation of the PIC architecture of the SC520 CPU (supports more IRQs) Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2009-03-20Rename SC520 Configuration OptionsGraeme Russ
Options are now all uniformly CONFIG_SYS_SC520_<option> Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-24Removed all references to CONFIG_SYS_RESET_GENERICGraeme Russ
Generic i386 reset - #define made redundant by weak function Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Added initial eNET board supportGraeme Russ
