path: root/include/configs/dxr2.h
2014-03-04arm: am335x: DXR2: Reset SMSC LAN9303 switch via GPIO upon bootupStefan Roese
Since the switch may be re-configured for VLAN usage in Linux (or any other OS), lets reset the switch to its default register values upon power-up. Otherwise network might not be available in U-Boot. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Roger Meier <r.meier@siemens.com> Cc: Lukas Stockmann <lukas.stockmann@siemens.com> Cc: Tom Rini <trini@ti.com>
2014-03-04drivers: net: cpsw: add support to have phy address from cpsw platform dataMugunthan V N
Some platforms like AM437x have different EVMs with different phy addresses, so this patch adds support for passing phy address via cpsw plaform data. Also renamed phy_id to phy_addr so better understanding of the code. Reviewed-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> [trini: Update BuR am335x_igep0033 pcm051_rev3 pcm051_rev1 cm_t335 pengwyn boards] Signed-off-by: Tom Rini <trini@ti.com>
2013-11-12arm, am335x: update for the siemens boardsSamuel Egli
- dxr2: define unused pins as input - do not enable RTC32K OSC on dxr2 board - update default environment - add splashpos=m,m to default environment, so splash screen is always centered. - adapt environment for bootcount feature - add altbootcmd to default environment - rut: SPL add early reset pulse for eth-phy, maXTouch and display - rut: display timing aenderungen - siemens boards: adapt for background color = white - add boutcount feature for the siemens boards store the bootcount in the environment, as we have no softreset save registers on this hardware. Use therefore the CONFIG_BOOTCOUNT_ENV bootcount driver. - change spi mode from 3 to 0 for the lcd init - add gpio pin for lcd reset with state 0 and add mdelay - siemens boards: use own USB id's - add dfu serial and device number for siemens boards Add for the siemens boards the possibility to define in dfu mode, the iSerialNumber and the bcdDevice fields in the USB Device descriptor. - fix upgrade mechanism based on bootcount Correct location of saveenv and remove not active variable. Add CONFIG_BOOT_RETRY_TIME and CONFIG_RESET_TO_RETRY to reboot board in case of empty kernel partition. Without these defines an empty kernel partition leads to an abort of boot process and one remains in u-boot prompt. - general cleanup of dxr2, pxm2 and rut boards all: * Remove net boot from bootcmd Ping can cause a crash on boards without ethernet phy. net_nfs command is used only for development * Add reset at the end of bootcmd In order to have an immediate reset of the boot when bootcmd fails, add reset at the end of bootcmd. rut: * add nand_img_size dxr2: * update nand_img_size * ddr3 timings updated with iocontrol property that can be modified via eeprom. New default parameters from software leveling with draco ES2. Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Signed-off-by: Pascal Bach <pascal.bach@siemens.com> Signed-off-by: Roger Meier <r.meier@siemens.com> Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Matthias Michel <matthias.michel@siemens.com> Cc: Tom Rini <trini@ti.com>
2013-08-28arm, am335x: add support for 3 siemens boardsHeiko Schocher
add support for the am335x based boards from siemens: dxr2: - DDR3 128MiB - NAND 256MiB - Ethernet with external Switch SMSC LAN9303 - no PMIC - internal Watchdog - DFU support pxm2: - DDR2 512 MiB - NAND 1024 MiB - PMIC - PHY atheros ar803x - USB Host - internal Watchdog - DFU support rut: - DDR3 256 MiB - NAND 256 MiB - PMIC - PHY natsemi dp83630 - external Watchdog - DFU support Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Roger Meier <r.meier@siemens.com> Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Cc: Pascal Bach <pascal.bach@siemens.com> Cc: Tom Rini <trini@ti.com>
