path: root/include/configs/ds414.h
2016-08-26spl: Remove unused CONFIG_SPL_SPI_* definitionsChris Packham
As of commit 88e34e5 ("spl: replace CONFIG_SPL_SPI_* with CONFIG_SF_DEFAULT_*") these defines are not used. Remove them to avoid confusion. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-01-14mvebu: Support Synology DS414Phil Sutter
This adds support for the MV78230 based DS414 NAS by Synology. The relevant bits have been extracted from the 'synogpl-5004-armadaxp' package Synology kindly published, garnished with a fair amount of trial-and-error. Sadly, support is far from perfect. The major parts I have failed in are SATA and XHCI support. Details about these and some other things follow: Device Tree ----------- The device tree file armada-xp-synology-ds414.dts has been copied from Linux and enhanced by recent U-Boot specific changes to armada-xp-gp.dts. SATA Support ------------ There is a Marvell 88SX7042 controller attached to PCIe which is supported by Linux's sata_mv driver but sadly not U-Boot's sata_mv. I'm not sure if extending the latter to support PCI devices is worth the effort at all. Porting sata_mv from Linux exceeded my brain's capacities. :( XHCI Support ------------ There is an EtronTech EJ168A XHCI controller attached to PCIe which drives the two rear USB3 ports. After a bit of playing around I managed to get it recognized by xhci-pci, but never was able to access any devices attached to it. Enabling it in ds414 board config shows that it does not respond to commands for whatever reason. The (somewhat) bright side to it is that it is not even supported in Synology's customized U-Boot, but that also means nowhere to steal the relevant bits from. EHCI Support ------------ This seems functional after issuing 'usb start'. At least it detects USB storage devices, and IIRC reading from them was OK. OTOH Linux fails to register the controller if 'usb start' wasn't given before in U-Boot. According to Synology sources, this board seems to support USB device (gadget?) mode. Though I didn't play around with it. PCIe Support ------------ This is fine, but trying to gate the clocks of unused lanes will hang PCI enum. In addition to that, pci_mvebu seems not to support DM_PCI. DDR3 Training ------------- Marvell/Synology uses eight PUPs instead of four. Does not look like this is meant to be customized in mainline U-Boot at all. OTOH I have no idea what a "PUP" actually is. PEX Init -------- Synology uses different values than mainline U-Boot with this patch: pex_max_unit_get returns 2, pex_max_if_get returns 7 and max_serdes_lines is set to 7. Not changing this seems to not have an impact, although I'm not entirely sure it does not cause issues I am not aware of. Static Environment ------------------ This allows to boot stock Synology firmware at least. In order to be a little more flexible when it comes to booting custom kernels, do not only load zImage partition, but also rd.gz into memory. This way it is possible to use about 7MB for kernel with piggyback initramfs. Signed-off-by: Phil Sutter <phil@nwl.cc> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
