path: root/include/configs/ds109.h
2019-04-02cosmetic: config: Remove empty #ifdefsLukasz Majewski
After running tools/moveconfig.py it turned out that for various boards there are an empty #ifdef statements. Remove them to clean u-boot source code. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-11-30arm: kirkwood: configs: ds109: Convert to DM_SPIChris Packham
Enable CONFIG_DM_SPI=y and CONFIG_DM_SPI_FLASH=y in the defconfig. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-02-13spi: Migrate CONFIG_KIRKWOOD_SPI to KconfigTuomas Tynkkynen
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-28arm: Note vendor-required status of certain MACH_TYPE valuesTom Rini
In the cases of some boards, a MACH_TYPE number is used which is either not registered upstream or worse (for functionality) is re-using the number of a different (or reference) platform instead. Make sure we have a comment in these cases. Cc: Albert ARIBAUD <albert.aribaud@3adev.fr> Cc: Walter Schweizer <swwa@users.sourceforge.net> Cc: Stefan Roese <sr@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de>
2016-10-09arm: kirkwood: add support for Synology DS109 boardWalter Schweizer
Synology DS109 is based on MV88F6281. The code is based on Dreamplug code with modificatons from Synologys open source repository. Signed-off-by: Walter Schweizer <swwa@users.sourceforge.net> Signed-off-by: Stefan Roese <sr@denx.de>
