path: root/include/configs/dreamplug.h
2015-11-17arm: kirkwood: Move common definitions into common fileQuentin Armitage
Create include/configs/mv-plug-common.h for common definitions for Sheevaplug, Guruplug and Dreamplug. This will make it easier to ensure the built u-boots stay in track with each other Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-17arm: kirkwood: Remove duplicate definition from dreamplug.hQuentin Armitage
CONFIG_DISPLAY_CPUINFO is already defined in mv-common.h Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-17arm: kirkwood: Align configuration filesQuentin Armitage
Cosmetic: CONFIG_OF_LIBFDT was in a different position in the config file for the Dreamplug, compared to the Sheevaplug and Guruplug. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-17arm: kirkwood: Move configuration of some commands to _defconfig filesQuentin Armitage
For Marvell plugs, move the configuration of DHCP, NAND/SF, PING and USB commands, and HUSH_PARSER into the _defconfig file, rather than the include/configs/*plug.h files. This avoids compiler warnings of duplicate definitions if the option is selected in the .config, but also defined in the include/configs/*plug.h file. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-17arm: kirkwood: standardise the configurationQuentin Armitage
The Marvell plugs are very similar systems, and so it makes sense for their u-boots to have the same commands/configuration. Add EXT4 and MII to Dreamplug, DATE to Guruplug and Sheevaplug. Add CONFIG_SYS_ALT_MEMTEST to Sheevaplug. There are still command differences around NAND, SPI/NOR. Also default to building u-boot.kwb for Sheevaplug and Guruplug. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-03-05dreamplug: set CONFIG_BUILD_TARGET to build u-boot.kwbIan Campbell
Saves having to remember to ask make for it explicitly. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
2015-03-05dreamplug: switch to GENERIC_BOARDIan Campbell
Built and booted to a Linux prompt with no issues discovered. network and usb access to the external mmc are ok. (my internal mmc is knackered at the h/w level). Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
2012-05-15ARM: dreamplug: Enable FDT supportIan Campbell
I have tested booting both FDT and non-FDT based Linux kernels (based on http://marc.info/?l=linux-arm-kernel&m=133002679716986 and http://marc.info/?l=linux-arm-kernel&m=132328894303581 respectively). Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Cc: Jason <jason@lakedaemon.net> Cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Jason Cooper <jason@lakedaemon.net>
2011-10-27dreamplug: initial board support.Jason Cooper
Copied wholeheartedly from board/Marvell/guruplug and modified to add support for SPI NOR flash. CONFIG_MACH_DREAMPLUG defined in include/configs/dreamplug.h until Linus's kernel.org tree adds it to mach-types.h. Once it trickles down, the definition can be removed from include/configs/dreamplug.h. Signed-off-by: Jason Cooper <u-boot@lakedaemon.net>
