path: root/include/configs/dragonboard820c.h
2019-06-14configs: Remove unneeded CONFIG_SYS_LDSCRIPT instancesTom Rini
A number of boards set CONFIG_SYS_LDSCRIPT and then end up using one of the default searched LDSCRIPT paths. Remove these customizations. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-23Remove config_distro_defaults.hAdam Ford
With the contents of config_distro_defaults.h migrated to Kconfig, we can remove this header file completely Signed-off-by: Adam Ford <aford173@gmail.com>
2018-02-08Move most CONFIG_HAVE_BLOCK_DEVICE to KconfigAdam Ford
config_fallbacks.h has some logic that sets HAVE_BLOCK_DEVICE based on a list of enabled options. Moving HAVE_BLOCK_DEVICE to Kconfig allows us to drastically shrink the logic in config_fallbacks.h Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rename HAVE_BLOCK_DEVICE to CONFIG_BLOCK_DEVICE] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-22fs: Migrate ext4 to KconfigTuomas Tynkkynen
Migrate the following symbols to Kconfig: CONFIG_FS_EXT4 CONFIG_EXT4_WRITE The definitions in config_fallbacks.h can now be expressed in Kconfig. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-15db820c: stop autoboot when vol- pressedJorge Ramirez-Ortiz
Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2018-01-15db820c: add qualcomm dragonboard 820C supportJorge Ramirez-Ortiz
This commit adds support for 96Boards Dragonboard820C. The board is based on APQ8086 Qualcomm Soc, complying with the 96Boards specification. Features - 4x Kyro CPU (64 bit) up to 2.15GHz - USB2.0 - USB3.0 - ISP - Qualcomm Hexagon DSP - SD 3.0 (UHS-I) - UFS 2.0 - Qualcomm Adreno 530 GPU - GPS - BT 4.2 - Wi-Fi 2.4GHz, 5GHz (802.11ac) - PCIe 2.0 - MIPI-CSI, MIPI-DSI - I2S U-Boot boots chained from LK (LK implements the fastboot protocol) in 64-bit mode. For detailed build instructions see readme.txt in the board directory. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
