path: root/include/configs/draco.h
2017-05-15watchdog: Migrate OMAP_WATCHDOG to KconfigTom Rini
Move this entry to Kconfig. As it is a hardware watchdog, select HW_WATCHDOG. While we could default to enabling this for all platforms, it is currently only enabled by default on AM33XX, so keep that logic today. Cc: Roger Meier <r.meier@siemens.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-12configs: convert CONFIG_SYS_MPUCLK to KconfigLokesh Vutla
Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-28arm: Clean up MACH_TYPE_xxx usage after re-sync of mach-typesTom Rini
With the latest mach-types values we have many instances where we no longer need to define a value and a few cases where the name (but not value) have changed slightly. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-18spl: Remove CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORSSemen Protsenko
This option isn't used for anything, so get rid of it. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-09-16Convert CONFIG_SPL_NET_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_NET_VCI_STRING to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SPL_NET_VCI_STRING Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_ETH_SUPPORT to KconfigSimon Glass
2016-06-09siemens,am33x: add draco etamin boardHeiko Schocher
In the draco CPU board family, etamin is a new variant with bigger flash and more RAM. Due to new flash that uses larger pages (4K) some changes are necessary because it impacts the MTD partition layout and the ubi mount parameters. Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Signed-off-by: Heiko Schocher <hs@denx.de> [trini: Move BOOTDELAY into defconfig, just always be 3 now] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-06-19arm, am33xx: update for siemens am335x based boardsHeiko Schocher
updates for the siemens am335x based boards: - draco: add delay for DDR3 configuration - change MTD partition layout and add a possibility to redefine MTD layout in board header. - move ubi support to common header file - draco: improve dtb naming - draco: set CONFIG_SYS_CBSIZE to 1024 - add generic env based led Leds can now be defined in Environment - add generic env based dfu button Which gpio is used for the dfu button can be defined through the Environment - set MACH_TYPE only if defined - draco: increase CPU freq to 300MHz - Add time command to siemens am33xx boards - DDR3: increase default tRFC - draco: enable pullup for DFU and ERST pin - change print format DDR3 Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Heiko Schocher <hs@denx.de>
2014-05-13siemens, draco: add new targetEgli, Samuel
Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Reviewed-by: Roger Meier <r.meier@siemens.com> Cc: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de>
