path: root/include/configs/dockstar.h
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
2013-03-04ubifs: Allow ubifsmount volume reference by numberJoe Hershberger
UBI can mount volumes by name or number The current code forces you to name the volume by prepending every name with "ubi:". >From fs/ubifs/super.c * There are several ways to specify UBI volumes when mounting UBIFS: * o ubiX_Y - UBI device number X, volume Y; * o ubiY - UBI device number 0, volume Y; * o ubiX:NAME - mount UBI device X, volume with name NAME; * o ubi:NAME - mount UBI device 0, volume with name NAME. Now any name passed in any of the above forms are allowed. Also update the configs that referenced ubifsmount. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2010-11-26Seagate FreeAgent DockStar supportEric Cooper
start with sheevaplug configuration add modifications by Alexander Holler <holler@ahsoftware.de> change RAM definitions to one bank (128 MB) change ident string and prompt define MTD partitions and default environment variables add support for LEDs Signed-off-by: Eric Cooper <ecc@cmu.edu>
