path: root/include/configs/dnp5370.h
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2015-06-01net: Fix NET_RANDOM_ETHADDR dependenciesMichal Simek
NET_RANDOM_ETHADDR depends on lib/rand.c. This patch adds dependency to Kconfig to ensure that library is also compiled. Remove the definitions from Blackfin boards' include/configs. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2014-05-12blackfin: replace bfin_gen_rand_mac() with eth_random_addr()Masahiro Yamada
bfin_gen_rand_mac() uses __DATE__ as the seed for random ethernet address. This makes the build non-deterministic. In the first place, it should not be implemented as a Bfin-specific function. Use eth_random_addr() instead. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Sonic Zhang <sonic.zhang@analog.com>
2013-12-06blackfin: Add missing macro CONFIG_BFIN_SERIALSonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2013-11-17Makefile: rename all libraries to built-in.oMasahiro Yamada
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: dnp5370: new board portAndreas Schallenberg
Info about the hardware can be found here: http://www.dilnetpc.com/dnp0086.htm Signed-off-by: Andreas Schallenberg <Andreas.Schallenberg@3alitydigital.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
