There was for long time no activity in the 4xx area.
We need to go further and convert to Kconfig, but it
turned out, nobody is interested anymore in 4xx,
so remove it.
CONFIG_CMD_IRQ
CONFIG_CMD_EEPROM
CONFIG_CMD_EEPROM_LAYOUT
CONFIG_EEPROM_LAYOUT_HELP_STRING
[trini: Rework Kconfig logic slightly, define EEPROM location on TI eval
platforms]
This subsystem is quite old. It has been replaced with a driver-model
version (UCLASS_THERMAL). Boards are free to convert to that if required,
but here is a removal patch that could be applied in the meantime.
We rename CONFIG_FIT_DISABLE_SHA256 to CONFIG_FIT_ENABLE_SHA256_SUPPORT which
is enabled by default and now a positive option. Convert the handful of boards
that were disabling it before to save space.
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Lukasz Dalek <luk0104@gmail.com>
CONFIG_CMD_DIAG
[trini: imply CMD_DIAG on some keymile configs]
CONFIG_BOARD_EARLY_INIT_F
Move the config IDENT_STRING to Kconfig and migrate all boards
[sivadur: Migrate zynq boards]
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
[trini: Update configs, add some default to sunxi Kconfig]
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards.
them from include/configs.
Tune dlvision configuration similar to other gdsys boards to reduce memory
footprint.
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Add the generic board infrastructure to all gdsys boards.
We do not have to define CONFIG_4xx in board config headers
because it is defined in arch/powerpc/cpu/ppc4xx/config.mk.
include/configs/JSE.h defines "CONFIG_4x", not "CONFIG_4xx".
I believe it is a typo because "CONFIG_4x" is not used at all
in other files.
So, I also deleted "CONFIG_4x" in include/configs/JSE.h.
CONFIG_SYS_FLASH_PROTECTION was active on most gdsys boards by default,
while hardware flash protection was not implemented.
Hardware support was added recently and we get into trouble because backward
compatibility is broken (u-boot can't unprotect the protected flash after a
downgrade). So we decided to disable hardware flash protection for all our boards.
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
Cc: Stefan Roese <sr@denx.de>
Tested-by: Stefan Roese <sr@denx.de>
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO
feature from U-Boot. It has only been implemented for PPC4xx and was not
used at all. So let's remove it and make the code smaller and cleaner.
Acked-by: Detlev Zundel <dzu@denx.de>
This patch removes the PPC4xx UART driver. Instead the common NS16550
driver is used, since all PPC4xx SoC's use this peripheral device.
The file 4xx_uart.c now only implements the UART clock calculation
function which also sets the SoC internal UART divisors.
All PPC4xx board config headers are changed to use this common NS16550
driver now.
Tested on these boards:
acadia, canyonlands, katmai, kilauea, sequoia, zeus
Board support for the Guntermann & Drunck DL-Vision.
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
