path: root/include/configs/digsy_mtc.h
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2014-10-27powerpc: digsy_mtc: convert to generic boardAnatolij Gustschin
2014-01-24powerpc: mpc5xxx: remove redundant CONFIG_MPC5xxx definitionMasahiro Yamada
We do not have to define CONFIG_MPC5xxx in board config headers (and start.S) because it is defined in arch/powerpc/cpu/mpc5xxx/config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-19CMD: Drop CONFIG_CMD_DFL, it's not usedMarek Vasut
$ git grep CMD_DFL board/atc/ti113x.c:#define CMD_DFLT (PCI_COMMAND_IO|PCI_COMMAND_MEMORY| \ board/atc/ti113x.c: pci_writew (s, PCI_COMMAND, CMD_DFLT); board/cpc45/pd67290.c:#define CMD_DFLT (PCI_COMMAND_IO|PCI_COMMAND_MEMORY| \ board/cpc45/pd67290.c: pci_writew (s, PCI_COMMAND, CMD_DFLT); drivers/pcmcia/i82365.c:#define CMD_DFLT (PCI_COMMAND_IO|PCI_COMMAND_MEMORY| \ drivers/pcmcia/i82365.c: pci_writew (s, PCI_COMMAND, CMD_DFLT); include/configs/MBX.h:#define CONFIG_CMD_DFL include/configs/MigoR.h:#define CONFIG_CMD_DFL include/configs/digsy_mtc.h:#define CONFIG_CMD_DFL include/configs/ms7722se.h:#define CONFIG_CMD_DFL include/configs/ms7750se.h:#define CONFIG_CMD_DFL include/configs/r2dplus.h:#define CONFIG_CMD_DFL include/configs/sh7757lcr.h:#define CONFIG_CMD_DFL include/configs/sh7785lcr.h:#define CONFIG_CMD_DFL Signed-off-by: Marek Vasut <marex@denx.de> Cc: Pfister_Werner@intercontrol.de Cc: iwamatsu@nigauri.org Cc: nobuhiro.iwamatsu.yj@renesas.com Cc: vapier@gentoo.org Cc: wd@denx.de Cc: yoshihiro.shimoda.uh@renesas.com Acked-by: Anatolij Gustschin <agust@denx.de> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-12-12mpc5200: digsy_mtc: Fix extension board detectionAnatolij Gustschin
Switch to extension board detection using pci_find_device() instead of detecting by i2c access to EEPROM device on extension board. This is a cleaner detection method since EEPROM addresses can be different on different board revisions. This also avoids "i2c_read: failed to address chip" error messages in the boot log on boards without extension board which may confuse users. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-10-15mpc5200: digsy_mtc: fix detection of Coral-PAAnatolij Gustschin
A delay of approximately 250 ms after PCI bus reset in pci_mpc5xxx_init() is needed to recognize the Coral-PA controller on the graphic extention board. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-08-04mpc5200: digsy_mtc: fix extension board EEPROM I2C address for rev5Anatolij Gustschin
On newer rev5 hardware the extension board EEPROM I2C address has been changed to 0x54. Make this I2C address configurable depending on CONFIG_DIGSY_REV5 so that extention board presence detection works correctly on newer hardware. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-07-27digsy_mtc: move board into vendor dir and add vendor logoAnatolij Gustschin
2011-07-27mpc5200: digsy_mtc: add support for graphic extension boardAnatolij Gustschin
Add detection and initialisation for graphic extension board and support splash screen when booting. Enable "bmp" command in the board configuration and provide "disp" command to be able to switch the display on/off. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-28mpc52xx, digsy_mtc: change phy addr for rev5 boards.Heiko Schocher
- rev5 board has phy addr 1 -> adapt CONFIG_PHY_ADDR define in board config file. - also fixup the phy addr entry in dts, before booting Linux. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-26mpc52xx, digsy_mtc: add trickle charger support for rev5 boards.Heiko Schocher
2011-03-21mpc52xx, digsy_mtc_rev5: Fix Linux crash, if no Flash in bank 2Heiko Schocher
If no Flash is connected to cs1, Linux crashes, because reg entries are not correct adapted. Following fix is needed: - swap base addresses in CONFIG_SYS_FLASH_BANKS_LIST, as flash bank 1 is on chipselect 0 and flash bank 2 on chipselect 1 - call fdt_fixup_nor_flash_size() from ft_board_setup() Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <hs@denx.de> cc: Werner Pfister <Pfister_Werner@intercontrol.de> cc: Detlev Zundel <dzu@denx.de>
2011-01-18mpc5200, digsy_mtc: add support for rev5 board versionHeiko Schocher
difference to previous board version: - M29W128GH flash from Numonyx - SDRAM ISSI IS45S16800 (Option A2 105°C) - rev5 uses RTC RV-3029-C2 - update cs0 and cs1 baseaddr and length depending on the detected flash size. - added Werner Pfister <Pfister_Werner@intercontrol.de> as maintainer for the digsy board variants - As the M29W128GH needs a special flash_cmd_reset() document that in the new file doc/README.cfi. - move "#endif /* CONFIG_CMD_IDE */" to the right place - remove LOWBOOT config option for digsy_mtc and digsy_mtc_rev5 boards - change doc/README.cfi as Stefan Roese suggested Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de> cc: Wolfgang Denk <hs@denx.de> cc: Stefan Roese <sr@denx.de> cc: Werner Pfister <Pfister_Werner@intercontrol.de> cc: Detlev Zundel <dzu@denx.de>
2009-09-24digsy_mtc: Add TCR register value for RTC (DS1339)Werner Pfister
Signed-off-by: Werner Pfister <werner.pfister@intercontrol.de> Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-08-09digsy_mtc: Update default environmentDetlev Zundel
2009-07-19digsy mtc: Enable command line history.Grzegorz Bernacki
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2009-06-14digsy mtc: Add description to GPIO initial configuration.Grzegorz Bernacki
2009-06-14digsy MTC: Add SPI support.Grzegorz Bernacki
2009-04-05Update CHANGELOG, coding style cleanup.Wolfgang Denk
2009-03-20Add support for the digsy MTC board.Grzegorz Bernacki
This is the InterControl custom device based on the MPC5200B chip. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
