path: root/include/configs/devkit8000.h
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-12ti: drop value from CONFIG_SYS_NAND_BUSWIDTH_16BITStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-04ti: armv7: Move SPL SDRAM init to the right place, drop unused CONFIG_SPL_STACKSimon Glass
Currently in some cases SDRAM init requires global_data to be available and soon this will not be available prior to board_init_f(). Adjust the code paths in these cases to be correct. In some cases we had the SPL stack be in DDR as we might have large stacks (due to Falcon Mode + Environment). In these cases switch to CONFIG_SPL_STACK_R. In other cases we had simply been setting CONFIG_SPL_STACK into SRAM. In these cases we no longer need to (CONFIG_SYS_INIT_SP_ADDR is used and is also in SRAM) so drop those lines. Signed-off-by: Simon Glass <sjg@chromium.org> Tested on Beagleboard, Beagleboard xM Tested-by: Matt Porter <mporter@konsulko.com> Tested on Beaglebone Black, AM43xx GP EVM, OMAP5 uEVM, OMAP4 Pandaboard Tested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-01-13arm: omap3: devkit8000: inherit from ti_omap3_common.hAnthoine Bourgeois
Signed-off-by: Anthoine Bourgeois <anthoine.bourgeois@gmail.com>
2015-01-13arm: omap3: devkit8000: inherit from ti_armv7_common.hAnthoine Bourgeois
2015-01-05devkit8000: convert to use generic board codeAnthoine Bourgeois
2014-12-04MMC SD fs boot partition config coding style and proper descriptionPaul Kocialkowski
CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION ought to be called CONFIG_SYS_MMCSD_FS_BOOT_PARTITION to keep it consistent with other config options such as: CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR. In addition, it is not related to raw mode booting but to fs mode instead. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com>
2014-10-27Rename some defines containing FAT in their name to be filesystem genericGuillaume GARDET
Rename some defines containing FAT in their name to be filesystem generic: MMCSD_MODE_FAT => MMCSD_MODE_FS CONFIG_SPL_FAT_LOAD_ARGS_NAME => CONFIG_SPL_FS_LOAD_ARGS_NAME CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME => CONFIG_SPL_FS_LOAD_PAYLOAD_NAME CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION => CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@ti.com>
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-25ARM: omap: clean redundant PISMO_xx macros used in OMAP3pekon gupta
PISMO_xx macros were used to define 'Platform Independent Storage MOdule' related GPMC configurations. This patch - Replaces these OMAP3 specific macros with generic CONFIG_xx macros as provided by current u-boot infrastructure. - Removes unused redundant macros, which are no longer required after merging of common platform code in following commit commit a0a37183bd75e74608bc78c8d0e2a34454f95a91 ARM: omap: merge GPMC initialization code for all platform +-----------------+-----------------------------------------------------------+ | Macro | Reason for removal | +-----------------+-----------------------------------------------------------+ | PISMO1_NOR_BASE | duplicate of CONFIG_SYS_FLASH_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_NAND_BASE| duplicate of CONFIG_SYS_NAND_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_ONEN_BASE| duplicate of CONFIG_SYS_ONENAND_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_NAND_SIZE| GPMC accesses NAND device via I/O mapped registers so | | | configuring GPMC chip-select for smallest allowable | | | segment (GPMC_SIZE_16M) is enough. | +-----------------+-----------------------------------------------------------+ | PISMO1_ONEN_SIZE| OneNAND uses a fixed GPMC chip-select address-space of | | | 128MB (GPMC_SIZE_128M) | +-----------------+-----------------------------------------------------------+ +-----------------+-----------------------------------------------------------+ | PISMO1_NOR | Unused Macros | | PISMO1_NAND | | | PISMO2_CS0 | | | PISMO2_CS1 | | | PISMO1_ONENAND | | | PISMO2_NAND_CS0 | | | PISMO2_NAND_CS1 | | | PISMO1_NOR_BASE | | | PISMO1_NAND_BASE| | | PISMO2_CS0_BASE | | +-----------------+-----------------------------------------------------------+ Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-06-06mtd: nand: omap: add CONFIG_SYS_NAND_BUSWIDTH_16BIT to indicate NAND device ↵pekon gupta
bus-width GPMC controller needs to be configured based on bus-width of the NAND device connected to it. Also, dynamic detection of NAND bus-width from on-chip ONFI parameters is not possible in following situations: SPL: SPL NAND drivers does not support ONFI parameter reading. U-boot: GPMC controller iniitalization is done in omap_gpmc.c:board_nand_init() which is called before probing for devices, hence any ONFI parameter information is not available during GPMC initialization. Thus, OMAP NAND driver expected board developers to explicitely write GPMC configurations specific to NAND device attached on board in board files itself. But this was troublesome for board manufacturers as they need to dive into lengthy platform & SoC documents to find details of GPMC registers and appropriate configurations to get NAND device working. This patch instead adds existing CONFIG_SYS_NAND_BUSWIDTH_16BIT to board config hich indicates that connected NAND device has x16 bus-width. And then based on this config GPMC driver itself initializes itself based on NAND bus-width. This keeps board developers free from knowing GPMC controller specific internals. Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-03-04mtd: nand: omap: remove unused #defines from common omap_gpmc.hpekon gupta
OMAP NAND driver can detect Page-size and OOB-size of NAND device from ONFI params or nand_id[] table. And based on that it defines ECC layout. This patch 1) removes following board configs used for defining NAND ECC layout - GPMC_NAND_ECC_LP_x16_LAYOUT (for large page x16 NAND) - GPMC_NAND_ECC_LP_x8_LAYOUT (for large page x8 NAND) - GPMC_NAND_ECC_SP_x16_LAYOUT (for small page x16 NAND) - GPMC_NAND_ECC_SP_x8_LAYOUT (for small page x8 NAND) 2) removes unused #defines in common omap_gpmc.h depending on above configs Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2013-11-25Merge branch 'master' of git://git.denx.de/u-boot-nand-flashTom Rini
2013-11-21mtd: nand: omap: add CONFIG_NAND_OMAP_ECCSCHEME for selection of ecc-schemepekon gupta
This patch adds new CONFIG_NAND_OMAP_ECCSCHEME, replacing other distributed CONFIG_xx used for selecting NAND ecc-schemes. This patch aims at solving following issues. 1) Currently ecc-scheme is tied to SoC platform, which prevents user to select other ecc-schemes also supported in hardware. like; - most of OMAP3 SoC platforms use only 1-bit Hamming ecc-scheme, inspite the fact that they can use higher ecc-schemes like 8-bit ecc-schemes with software based error detection (OMAP_ECC_BCH4_CODE_HW_DETECTION_SW). - most of AM33xx SoC plaforms use 8-bit BCH ecc-scheme for now, but hardware supports BCH16 ecc-scheme also. 2) Different platforms use different CONFIG_xx to select ecc-schemes, which adds confusion for user while migrating platforms. - *CONFIG_NAND_OMAP_ELM* which enables ELM hardware engine, selects only 8-bit BCH ecc-scheme with h/w based error-correction (OMAP_ECC_BCH8_CODE_HW) whereas ELM hardware engine supports other ecc-schemes also like; BCH4, and BCH16 (in future). - *CONFIG_NAND_OMAP_BCH8* selects 8-bit BCH ecc-scheme with s/w based error correction (OMAP_ECC_BCH8_CODE_HW_DETECTION_SW). - *CONFIG_SPL_NAND_SOFTECC* selects 1-bit Hamming ecc-scheme using s/w library Thus adding new *CONFIG_NAND_OMAP_ECCSCHEME* de-couples ecc-scheme dependency on SoC platform and NAND driver. And user can select ecc-scheme independently foreach board. However, selection some hardware based ecc-schemes (OMAP_ECC_BCHx_CODE_HW) still depends on presence of ELM hardware engine on SoC. (Refer doc/README.nand) Signed-off-by: Pekon Gupta <pekon@ti.com>
2013-11-13i2c, omap24xx: convert driver to new mutlibus/mutliadapter frameworkHeiko Schocher
- add omap24xx driver to new multibus/multiadpater support - adapted all config files, which uses this driver Tested on the am335x based siemens boards rut, dxr2 and pxm2 posted here: http://patchwork.ozlabs.org/patch/263211/ Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Tom Rini <trini@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Thomas Weber <weber@corscience.de> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Nishanth Menon <nm@ti.com> Cc: Pali Rohár <pali.rohar@gmail.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Michael Jones <michael.jones@matrix-vision.de> Cc: Raphael Assenat <raph@8d.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefano Babic <sbabic@denx.de>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-08-15ARM: OMAP: Add CONFIG_OMAP_COMMONLokesh Vutla
Adding a new CONFIG_OMAP_COMMON which is included by all boards that needs to build cpu/armv7/omap-common folder. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-06-07devkit8000: Add SPL_OS for MMC supportTom Rini
2013-03-01OMAP3: drop CONFIG_SPL_OS_BOOT_KEY and use local defineStefano Babic
CONFIG_SPL_OS_BOOT_KEY is used only in board files. It is not required to have a general CONFIG_ option. Rename it and define it in board directory. Signed-off-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2013-01-29Remove unused CONFIG_SYS_I2C_BUS[_SELECT]Michael Jones
"CONFIG_SYS_I2C_BUS" and "CONFIG_SYS_I2C_BUS_SELECT" don't appear anywhere outside of config files. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-11-26spl/nand: introduce CONFIG_SPL_NAND_DRIVERS, _BASE, and _ECC.Scott Wood
Some small SPLs do not use nand_base.c, and a subset of those also require a special driver. Some SPLs need software ECC but others can't fit it. All existing boards that specify CONFIG_SPL_NAND_SUPPORT have these symbols added to preserve existing behavior. Signed-off-by: Scott Wood <scottwood@freescale.com> -- v2: use positive logic for including bits of NAND, rather than a MINIMAL symbol that excludes things.
2012-10-23configs: Fix usage of mmc rescanAndrew Bradford
Fix usage of 'mmc rescan' by many configs. Proper use is 'mmc dev ${mmcdev}; mmc rescan' to set the mmc device and then rescan the device. 'mmc rescan' itself does not take any arguments. Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
2012-10-01devkit8000: add rootwait to mmcboot optionAndreas Bießmann
Signed-off-by: Andreas Bießmann <biessmann@corscience.de> cc: Thomas Weber <weber@corscience.de>
2012-09-27SPL: Move the omap SPL framework to common/splTom Rini
Add a new flag, CONFIG_SPL_FRAMEWORK to opt into the common/spl SPL framework, enable on all of the previously using boards. We move the spl_ymodem.c portion to common/ and spl_mmc.c to drivers/mmc/. We leave the NAND one in-place as we plan to replace it later in this series. We use common/spl to avoid linker problems with respect to merging constant strings in objects. Otherwise all strings in common/ will be linked in and kept which grows SPL in size too much. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01dm: Move OMAP GPIO driver to drivers/gpio/Marek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: U-Boot DM <u-boot-dm@lists.denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01dm: Select CONFIG_SPL_GPIO_SUPPORT on OMAPMarek Vasut
This fixes the breakage with SPL on most OMAP boards after the GPIO driver was moved. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: U-Boot DM <u-boot-dm@lists.denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-05-15ARM: omap3: Set SPL stack size to 8KB, image to 54KB.Tom Rini
With older toolchains it is possible to not fit entirely into the 45KB that we had assigned to SPL. Adjust to allow for 8KB of stack (which should be more than required) and 54KB of text/data. Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Thomas Weber <weber@corscience.de> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Vaibhav Hiremath <hvaibhav@ti.com>
2012-03-27devkit8000: Implement and activate direct OS bootSimon Schwarz
- Implements spl_start_uboot() for devkit8000 - Add configs to activate direct OS boot from SPL Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> CC: Tom Rini <tom.rini@gmail.com> CC: Stefano Babic <sbabic@denx.de> CC: Wolfgang Denk <wd@denx.de>
2012-03-27devkit8000: add config for spl commandSimon Schwarz
This adds some configs for devkit8000 to use the new spl command Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> CC: Tom Rini <tom.rini@gmail.com> CC: Stefano Babic <sbabic@denx.de> CC: Wolfgang Denk <wd@denx.de>
2012-01-26nand_spl_simple: store ecc data on the stackStefano Babic
Currently nand_spl_simple puts it's temp data at 0x10000 offset in SDRAM which is likely to contain already loaded data. The patch saves the oob data and the ecc on the stack replacing the fixed address in RAM. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Ilya Yanok <yanok@emcraft.com> CC: Scott Wood <scottwood@freescale.com> CC: Tom Rini <tom.rini@gmail.com> CC: Simon Schwarz <simonschwarzcor@googlemail.com> CC: Wolfgang Denk <wd@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-12-06devkit8000: Move CONFIG_SYS_TEXT_BASE out of bssSimon Schwarz
This moves CONFIG_SYS_TEXT_BASE one MB after beginning of SD-RAM. Move CONFIG_SYS_SPL_MALLOC_START to have one MB of free space for the u-boot image. CONFIG_SYS_TEXT_BASE was in the middle of the bss-section. This was the reason for the problems with MMC boot described here: http://article.gmane.org/gmane.comp.boot-loaders.u-boot/118711 Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Tested-by: Thomas Weber <weber@corscience.de> Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06OMAP3: Add SPL_BOARD_INIT hookTom Rini
Add an SPL_BOARD_INIT hook and for OMAP3 have it turn on i2c. OMAP4 doesn't need i2c enabled in SPL. Enable SPL_BOARD_INIT on devkit8000. Cc: Frederik Kriewitz <frederik@kriewitz.eu> Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06OMAP3 SPL: Rework memory initalization and devkit8000 supportTom Rini
This changes to making the board be responsible for providing the memory initialization timings in SPL and converts the devkit8000 to this framework. In SPL we try and initialize both CS0 and CS1. Cc: Frederik Kriewitz <frederik@kriewitz.eu> Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06ARM: OMAP: Remove STACKSIZE for IRQ and FIQ if unusedThomas Weber
This patch removes the definition of stack sizes for irq and fiq if the CONFIG_USE_IRQ is undefined before. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-12-06ARM: OMAP3: Remove unused define SDRC_R_C_BThomas Weber
This patch removes the unused definition of SDRC_R_C_B from the config files. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it> Acked-by: Tom Rini <trini@ti.com>
2011-12-06ARM: OMAP3: Remove unused define CONFIG_OMAP3430Thomas Weber
This patch removes the CONFIG_OMAP3430, because it is unused. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-11-10devkit8000: Fix NAND SPL on boards with 256MB NANDTom Rini
The devkit8000 ships with either a 128MB or 256MB NAND chip. In order for SPL to work with 256MB NAND CONFIG_SYS_NAND_5_ADDR_CYCLE needs to be set. After talking with Scott Wood this should be safe to set even for smaller NAND chips. Cc: Scott Wood <scottwood@freescale.com> Cc: Frederik Kriewitz <frederik@kriewitz.eu> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27devkit8000: Add malloc spaceTom Rini
With malloc support being a new requirement for all ARM SPL implementations, define a small area for use on devkit8000. Cc: Frederik Kriewitz <frederik@kriewitz.eu> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27devkit8000: Add config to enable SPL MMC bootSimon Schwarz
Add MMC boot configs to devkit8000 config. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com>
