CONFIG_LPC32XX_ETH
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_RMII
CONFIG_SYS_FAULT_ECHO_LINK_DOWN
CONFIG_BOOTFILE
Use moveconfig.py script to convert define CONFIG_SYS_MAX_FLASH_BANKS
and CONFIG_SYS_MAX_FLASH_BANKS_DETECT to Kconfig and move these entries
to defconfigs.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
[trini: Re-switch to IS_ENABLED check in spi-nor-core.c, re-run migration]
CONFIG_CONS_INDEX
CONFIG_DEBUG_UART_CLOCK
CONFIG_FSL_TZPC_BP147
CONFIG_GENERIC_ATMEL_MCI
CONFIG_IDENT_STRING
CONFIG_LIBATA
CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE
CONFIG_LPC32XX_GPIO
CONFIG_MP
CONFIG_MPC8XXX_GPIO
CONFIG_MTD_PARTITIONS
CONFIG_MVGBE
CONFIG_MXC_GPIO
CONFIG_NR_DRAM_BANKS
CONFIG_OF_BOARD_SETUP
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_OF_SYSTEM_SETUP
CONFIG_PREBOOT
CONFIG_ROCKCHIP_SERIAL
CONFIG_RTC_ENABLE_32KHZ_OUTPUT
CONFIG_RTC_MV
CONFIG_SCSI_AHCI
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_SPEED
CONFIG_SOFT_SPI
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_MTD
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_STMICRO
CONFIG_SUPPORT_RAW_INITRD
CONFIG_SYS_ARCH_TIMER
CONFIG_SYS_BOARD
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_DCACHE_OFF
CONFIG_SYS_FDT_SAVE_ADDRESS
CONFIG_SYS_FLASH_CFI
CONFIG_SYS_FSL_ERRATUM_ESDHC135
CONFIG_SYS_HAS_SERDES
CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_LITTLE_ENDIAN
CONFIG_SYS_LOAD_ADDR
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
CONFIG_SYS_NS16550
CONFIG_SYS_PLLFIN
CONFIG_SYS_SPI_U_BOOT_OFFS
CONFIG_TIMER_SYS_TICK_CH
CONFIG_USB_EHCI_FSL
CONFIG_U_QE
CONFIG_VERSION_VARIABLE
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_SYS_NAND_U_BOOT_LOCATIONS
CONFIG_SYS_NAND_U_BOOT_OFFS
CONFIG_SPL_NAND_LOAD
CONFIG_SYS_NAND_BLOCK_SIZE
CONFIG_SYS_NAND_PAGE_SIZE
CONFIG_SYS_NAND_OOBSIZE
As this is only useful when booting with ATAGs, which are now largely
disabled, remove this value for the remaining platforms. We have a few
places in the code that had been testing for MACH_TYPE as a sort of
internal logic. Update those to use different but still correct CONFIG
symbols.
Cc: Phil Sutter <phil@nwl.cc>
With the exceptions of ds109, ds414, icnova-a20-swac, nokia_rx51 and
stemmy, disable ATAG support. A large number of platforms had enabled
support but never supported a kernel so old as to require it. Further,
some platforms are old enough to support both, but are well supported by
devicetree booting, and have been for a number of years. This is
because some of the ATAGs related functions have been re-used to provide
the same kind of information, but for devicetree or just generally to
inform the user. When needed still, rename these functions to
get_board_revision() instead, to avoid conflicts. In other cases, these
functions were simply unused, so drop them.
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Stefan Bosch <stefan_b@posteo.net>
CONFIG_DMA_LPC32XX
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
- In most of the codebase, we reference CONFIG_SYS_LOAD_ADDR and not
CONFIG_LOADADDR.
- Generally, CONFIG_SYS_LOADADDR is set to CONFIG_LOADADDR and then as
noted, we use CONFIG_SYS_LOADADDR.
CONFIG_SYS_I2C_SPEED
CONFIG_SYS_I2C_SLAVE
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
It is quite confusing that CONFIG_SYS_I2C selects the legacy I2C and
CONFIG_DM_I2C selects the current I2C. The deadline to migrate I2C is less
than a year away.
Also we want to have a CONFIG_I2C for U-Boot proper just like we have
CONFIG_SPL_I2C for SPL, so we can simplify the Makefile rules.
Rename this symbol so it is clear it is going away.
Convert the CONFIG_SYS_I2C_LPC32XX configuration symbol from an include
directive to a Kconfig value.
Signed-off-by: Trevor Woerner <twoerner@gmail.com>
There's nothing special or unique to the lpc32xx that requires its own config
parameter for specifying the console uart index. Therefore instead of using
the lpc32xx-specific CONFIG_SYS_LPC32XX_UART include parameter, use the
already-available CONFIG_CONS_INDEX from Kconfig.
CONFIG_SPL_NAND_DRIVERS
CONFIG_SPL_NAND_ECC
CONFIG_SPL_NAND_SIMPLE
lpc32xx_ssp driver is deprecated, no active updates
and no board user, hence dropped the same.
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: Albert ARIBAUD <albert.aribaud@3adev.fr>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Convert CONFIG_SYS_NAND_USE_FLASH_BBT to Kconfig, update defconfigs,
headers and whitelist.
Please note that this symbol already was used in Kconfig
(imply in CONFIG_NAND_ATMEL) which did not work, since this symbol was
not available in Kconfig. This changes now with this patch and all
boards with CONFIG_NAND_ATMEL will have BBT enabled. Which is what
I also need on my GARDENA AT91SAM based board.
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Cc: Miquel Raynal <miquel.raynal@bootlin.com>
Cc: Gregory CLEMENT <gregory.clement@bootlin.com>
[trini: Rework such that the configs are unchanged to start with]
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig
parameters; only for the ARC architecture. This patch turns these two
parameters into Kconfig items everywhere else they are found.
All of the include/configs/* and defconfig changes in this patch are
for arm machines only. The Kconfig changes for arc, nds32, riscv,
and xtensa have been included since these symbols are found in code
under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined
include/configs/* or defconfigs for these architectures exist which
include these symbols.
These results have been confirmed with tools/moveconfig.py.
Acked-by: Alexey Brodkin <abrodkin@snopsys.com>
Signed-off-by: Trevor Woerner <trevor@toganlabs.com>
[trini: Re-migrate for a few more boards]
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_FLASH_CFI_DRIVER
CONFIG_SYS_FLASH_USE_BUFFER_WRITE
CONFIG_FLASH_CFI_MTD
CONFIG_SYS_FLASH_PROTECTION
[trini: Re-migrate]
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_NAND_LPC32XX_SLC
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
CONFIG_PHY_ADDR is used for old-style configuration. This makes
impossible changing the PHY address, if multiple boards share a same
config header file (for example include/configs/sunxi-common.h).
Moving this to Kconfig helps overcoming this issue. It's defined
as entry inside PHYLIB section.
After the implemention, moveconfig was run. The issues are:
- edb9315a - CONFIG_PHYLIB is not enabled. Entry is
deleted.
- ds414 - CONFIG_PHYLIB is in incompatible format:
{ 0x1, 0x0 }. This entry is also deleted.
- devkit3250 - The PHY_ADDR is in hex format (0x1F).
Manually CONFIG_PHY_ADDR=31 is added in
the defconfig.
After the changes the suspicious defconfigs passes building.
Signed-off-by: Stefan Mavrodiev <stefan@olimex.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
[jagan: rebased on master]
Reviewed-by: Jagan Teki <jagan@openedev.com>
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
Migrate the option CONFIG_SPL_FRAMEWORK and make this gate most of the
current set of options we have in Kconfig. We will need to have some
options available for SPL and !SPL_FRAMEWORK so this is important. In a
few cases we re-order existing options so that we have less escapes from
the SPL_FRAMEWORK guard.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
CONFIG_NAND_MXC
CONFIG_NAND_OMAP_GPMC
CONFIG_NAND_OMAP_GPMC_PREFETCH
CONFIG_NAND_OMAP_ELM
CONFIG_SPL_NAND_AM33XX_BCH
CONFIG_SYS_NAND_BUSWIDTH_16BIT
[trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues,
add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT]
Now that include/config_fallbacks.h define a sane fallback for
CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all
configurations that were using the default value.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Now that the fallback value of CONFIG_SYS_PBSIZE in
include/config_fallbacks.h has been adjusted, remove its definition
from a large number of board configuration files.
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
Migrate all remaining instances of CMD_NAND, CMD_NAND_TRIMFFS
CMD_NAND_LOCK_UNLOCK and CMD_NAND_TORTURE from the headers into the
defconfig files.
Tested-by: Adam Ford <aford173@gmail.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
CONFIG_CMD_JFFS2
CONFIG_SPL_BOARD_INIT
Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
[trini: Update the Kconfig logic]
Move this in to Kconfig with a default of 115200.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
[trini: Run moveconfig.py, reword commit slightly]
With the latest mach-types values we have many instances where we no
longer need to define a value and a few cases where the name (but not
value) have changed slightly.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
