path: root/include/configs/devkit3250.h
2019-05-18CONFIG_SYS_[DI]CACHE_OFF: convert to KconfigTrevor Woerner
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig parameters; only for the ARC architecture. This patch turns these two parameters into Kconfig items everywhere else they are found. All of the include/configs/* and defconfig changes in this patch are for arm machines only. The Kconfig changes for arc, nds32, riscv, and xtensa have been included since these symbols are found in code under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined include/configs/* or defconfigs for these architectures exist which include these symbols. These results have been confirmed with tools/moveconfig.py. Acked-by: Alexey Brodkin <abrodkin@snopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Re-migrate for a few more boards] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-07-21Convert CONFIG_NAND_LPC32XX_SLC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_LPC32XX_SLC Signed-off-by: Adam Ford <aford173@gmail.com>
2018-03-13Move CONFIG_PHY_ADDR to KconfigStefan Mavrodiev
CONFIG_PHY_ADDR is used for old-style configuration. This makes impossible changing the PHY address, if multiple boards share a same config header file (for example include/configs/sunxi-common.h). Moving this to Kconfig helps overcoming this issue. It's defined as entry inside PHYLIB section. After the implemention, moveconfig was run. The issues are: - edb9315a - CONFIG_PHYLIB is not enabled. Entry is deleted. - ds414 - CONFIG_PHYLIB is in incompatible format: { 0x1, 0x0 }. This entry is also deleted. - devkit3250 - The PHY_ADDR is in hex format (0x1F). Manually CONFIG_PHY_ADDR=31 is added in the defconfig. After the changes the suspicious defconfigs passes building. Signed-off-by: Stefan Mavrodiev <stefan@olimex.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> [jagan: rebased on master] Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-02-13spi: Migrate CONFIG_LPC32XX_SSP to KconfigTuomas Tynkkynen
2017-10-20Convert CONFIG_NAND_OMAP_GPMC et al and CONFIG_NAND_MXC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_MXC CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE CONFIG_SYS_NAND_BUSWIDTH_16BIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues, add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_JFFS2 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_JFFS2 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-28arm: Clean up MACH_TYPE_xxx usage after re-sync of mach-typesTom Rini
With the latest mach-types values we have many instances where we no longer need to define a value and a few cases where the name (but not value) have changed slightly. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-07-01autoboot: remove CONFIG_ZERO_BOOTDELAY_CHECKMasahiro Yamada
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2 means the autoboot with no delay, with no abort check even if CONFIG_ZERO_BOOTDELAY_CHECK is defined. To sum up, the autoboot behaves as follows: [1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n autoboot with no delay, with no check for abort [3] CONFIG_BOOTDELAY=-1 disable autoboot [4] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort As you notice, [2] and [4] come to the same result, which means we do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the cases only by CONFIG_BOOTDELAY, like this: [1] CONFIG_BOOTDELAY=0 autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=-1 disable autoboot [3] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort This commit converts the logic as follow: CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n --> CONFIG_BOOTDELAY=-2 Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Christian Riesch <christian.riesch@omicronenergy.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2016-01-13lpc32xx: devkit3250: update board configuration fileVladimir Zapolskiy
The change updates DevKit3250 board powerd by NXP LPC3250 SoC: * due to increased resulting U-boot image size give more space to store loaded and relocated versions, * add DMA support, which is used by NAND SLC driver, * add NXP OHCI and PHY drivers to the image, * add USB, JFFS and FAT commands. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2015-08-18lpc32xx: move common SLC NAND defines to arch/config.hVladimir Zapolskiy
A number of LPC32xx SLC NAND defines is dictated by controller hardware limits and OOB layout is defined by operating system, the definitions are common for all users. Since those macro are used in out of NAND SLC driver code (simple NAND SPL framework), they can not be placed into the driver, therefore move them from board config files to arch/config.h The change also adds OOB layout details specific to small page NAND devices taken from Linux kernel. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Tested-by: Sylvain Lemieux <slemieux@tycoint.com>
2015-08-12lpc32xx: devkit3250: add spl build supportVladimir Zapolskiy
The change adds SPL build support to Timll DevKit3250 board, the generated SPL image can be uploaded over UART5, JTAG or stored on NAND. SPL is designed to load U-boot image from NAND. All new NAND chip defines in board configuration are needed by SPL NAND "simple" framework, the framework is used to reduce potentially duplicated code from LPC32xx SLC NAND driver. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2015-08-12lpc32xx: devkit3250: update of board configurationVladimir Zapolskiy
This change adds more peripherals to Timll DevKit3250 board, namely MAC and SMSC phy, SLC NAND, GPIO, SPI and I2C. Also the default serial console is changed to UART5, added an option to pass device tree blob by means of bootm, predefined environment variables are slightly extended and reserved space on NAND to store user defined U-boot environment. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2014-03-04sizes.h - consolidate for all architecturesAlexey Brodkin
Copied from Linux sources "include/linux/sizes.h" commit 413541dd66d51f791a0b169d9b9014e4f56be13c Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com> Acked-by: Stefan Roese <sr@denx.de> [trini: Add bcm Kona platforms to the patch] Signed-off-by: Tom Rini <trini@ti.com>
2014-02-19configs: Delete obsolete macro, CONFIG_SYS_GBL_DATA_SIZEMasahiro Yamada
CONFIG_SYS_GBL_DATA_SIZE is not used any more. The size of struct "global_data" is automatically calculated by asm-offsets. (See lib/asm-offsets.c) GENERATED_GBL_DATA_SIZE should be used instead of CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-05-15devkit3250: add Timll DevKit3250 board initial supportVladimir Zapolskiy
This change adds a basic support for Embest/Timll DevKit3250 board, NOR and UART are the only supported peripherals for a moment. The board doesn't require low-level init, because the initial SDRAM and GPIO configuration is performed during kickstart bootloader execution. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Marek Vasut <marek.vasut@gmail.com>
