path: root/include/configs/db-mv784mp-gp.h
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-26spl: Remove unused CONFIG_SPL_SPI_* definitionsChris Packham
As of commit 88e34e5 ("spl: replace CONFIG_SPL_SPI_* with CONFIG_SF_DEFAULT_*") these defines are not used. Remove them to avoid confusion. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-01-14arm: mvebu: Move SoC selection (A38X vs AXP) into KconfigStefan Roese
Until now, the SoC selection for the ARCH_MVEBU platforms has been done in the config header. Using CONFIG_ARMADA_XP in a non-clear way. As it needed to get selected for AXP and A38x based boards. This patch now changes this to move the SoC selection to Kconfig. And also uses CONFIG_ARCH_MVEBU as a common define for both AXP and A38x. This makes things a bit clearer - especially for new board additions. Additionally the defines CONFIG_SYS_MVEBU_DDR_AXP and CONFIG_SYS_MVEBU_DDR_A38X are replaced with the already available CONFIG_ARMADA_38X and CONFIG_ARMADA_XP. And CONFIG_DDR3 is removed, as its not referenced anywhere. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Make ECC support configurable on Armada XPStefan Roese
Currently, ECC support is enabled for all Armada XP boards. So the DDR3 driver tries to configure the controller with ECC support, even on boards without ECC. This patch makes this ECC optional which now can be configured on a board-per-board basis. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Phil Sutter <phil@nwl.cc>
2016-01-14arm: mvebu: db-mv784mp-gp: Enable cache commandStefan Roese
Th cache command can be useful sometimes. So lets enable it on the AXP eval board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: db-mv784mp-gp: Enable common file-system supportStefan Roese
This patch adds the common FS options to the Marvell AXP eval board. This includes EXT2, EXT4, FAT and VFAT. And of course the generic FS commands. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: db-mv784mp-gp: Switch from IDE to SATA supportStefan Roese
Enable the newly introduced SATA driver for the Marvell AXP with DMA support instead of the PIO-only IDE driver. This increases the transfer speed. And is also more in-line with the Armada 38x ports, which also use a SATA driver (AHCI) and the "sata" U-Boot commands. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Move some defines to common include fileStefan Roese
This patch moves some config options to the mvebu common include file. Making it easier to not forget these defines for new boards. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc>
2016-01-14net: mvneta: Convert to driver modelStefan Roese
Update this driver to support driver model. As all MVEBU boards using this driver are converted with this patch, the non-driver-model code can be removed completely. This is also the reason why this patch is quite big and includes a) the driver change and b) the platform change. As its not git-bisect save otherwise. With this conversion, some parameters are now extracted from the DT instread of using the config header defines. The supported properties right now are: PHY-mode ("phy-mode") and PHY-address ("reg"). The base addresses for the ethernet controllers can be removed from the header files as well. Please note that this patch also removes the E1000 network driver from some MVEBU config headers. This is necessary, as with DM_ETH configured and the e1000 driver enabled, the PCI driver also needs to support DM. But the MVEBU PCI(e) driver still needs to get ported to DM. When this is done, the E1000 driver can be enabled again. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Simon Glass <sjg@chromium.org>
2016-01-14arm: mvebu: Add DM and OF_CONTROL support to SPLStefan Roese
This patch adds full DM support to the SPL on MVEBU. Currently only serial is supported. Other drivers will follow. This patch also adds the necessary config values for the DEBUG UART to the MVEBU defconfig files. This came in handy while implementing this DM support. Additionally, the mvebu specific SPL linker script is removed and this common one is used instead: arch/arm/cpu/u-boot-spl.lds This common linker script already handles all special cases. No need to reinvent the wheel for MVEBU here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Simon Glass <sjg@chromium.org>
2015-10-21arm: mvebu: Enable DM_USB on AXP / A38x boardsStefan Roese
This patch enables DM_USB on the Marvell AXP / A38x eval boards. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-10-21arm: mvebu: Only set CONFIG_SKIP_LOWLEVEL_INIT for SPLStefan Roese
When running on the AXP I sometimes noticed a strange behavior. As some characters are not echoed on the U-Boot prompt. Not disabling the lowlevel_init code, especially calling cpu_init_cp15() in the main U-Boot seems to solve this issue. Signed-off-by: Stefan Roese <sr@denx.de>
2015-08-25arm: mvebu: Enable NAND on db-mv784mp-gpStefan Roese
This patch enables NAND support on the Marvell Armada XP DB-MV784MP-GP eval board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Peter Morrow <peter@senient.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-08-17arm: mvebu: db-mv784mp-gp: Enable PCI supportStefan Roese
This patch enabled the MVEBU PCIe support on the db-mv784mp-gp AXP eval board. It also enabled the Intel E1000 driver support and adds the initialization of PCIe network controllers to the board code. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Anton Schubert <anton.schubert@gmx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-08-17arm: mvebu: Move CONFIG_SYS_TEXT_BASE to an address < 16 MiBStefan Roese
This patch moves CONFIG_SYS_TEXT_BASE to 0x00800000 for all Armada XP / 38x boards in mainline U-Boot. This is done in preparation for the ECC SDRAM scrubbing that needs to be done in the main U-Boot. The SPL (previously bin_hdr) has already scrubbed the area: 0x0000.0000 - 0x0100.0000 In this area this main U-Boot needs to get loaded. The main U-Boot then can scrub the remaining SDRAM area while running from this location. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-08-17arm: mvebu: add multiple usb-hostcontroller support for AXPAnton Schubert
This patch adds support for multiple hostcontrollers to the ehci-marvell driver and enables all 3 usb-hcs on the db-mv784mp-gp board. It depends on the initial Armada XP usb support patch from Stefan. Signed-off-by: Anton Schubert <anton.schubert@gmx.de> Reviewed-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-08-17arm: mvebu: db-mv785mp-gp: Add USB/EHCI supportStefan Roese
This patch enabled the USB/EHCI support for the Marvell DB-MV784MP-GP Armada XP eval board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Anton Schubert <anton.schubert@gmx.de> Cc: Marek Vasut <marex@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-08-17arm: mvebu: db-mv784mp-gp.h: Fix image creation - use correct offsetStefan Roese
2015-07-23arm: mvebu: drivers/ddr: Move Armada XP DDR init code into new directoryStefan Roese
With the upcoming addition of the Armada 38x DDR support, which is not compatible to the Armada XP DDR init code, we need to introduce a new directory infrastructure. To support multiple Marvell DDR controller. This will be the new structure: drivers/ddr/marvell/axp Supporting Armada XP (AXP) devices (and perhaps Armada 370) drivers/ddr/marvell/a38x Supporting Armada 38x devices (and perhaps Armada 39x) Signed-off-by: Stefan Roese <sr@denx.de>
2015-07-23arm: mvebu: add Armada XP SATA supportAnton Schubert
This patch initializes the SATA address windows on Armada XP and allows it to work with the existing mvsata_ide driver. It also adds the necessary configuration for the db-mv784mp-gp board. Signed-off-by: Anton Schubert <anton.schubert@gmx.de> Tested-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-05-05arm: mvebu: Change network init code to allow a more flexible setupStefan Roese
With the introduction of the Armada 38x support, its necessary to change the mvneta ethernet driver init call from always 4 times to a configurable value. Lets make this init call more flexible by moving the actually used devices to the config header. Additionally this patch takes care of the slightly different base addresses for the ethernet controllers on A38x. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-05arm: mvebu: Move CONFIG_SPL_LDSCRIPT to common headerStefan Roese
This way, new MVEBU boards don't need to specifiy the common location for the SPL linker script. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-05-05arm: mvebu: Move mvebu-common into mach-mvebuStefan Roese
Now that the mach-mvebu directory exists and is used by Armada XP we can move the mvebu-common files into this directory as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-04-15i2c: mvtwsi: Support for up to 4 different controllersPaul Kocialkowski
Orion5x, Kirkwood and Armada XP platforms come with a single TWSI (I2C) MVTWSI controller. However, other platforms using MVTWSI may come with more: this is the case on Allwinner (sunxi) platforms, where up to 4 controllers can be found on the same chip. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-06arm: db-mv784mp-gp: Enable SPL to include DDR training code into U-BootStefan Roese
This patch adds SPL support to the db-mv784mp-gp eval board. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
2014-10-23arm: armada-xp: Add basic support for the Marvell DB-MV784MP-GP boardStefan Roese
This patch adds basic support for the Marvell DB-MV784MP-GP evaulation board. This is the first board that uses the recently created Armada XP 78460 SoC support. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org>
