path: root/include/configs/davinci_schmoogie.h
2010-12-17DaVinci Schmoogie: Add ARM Relocation SupportSandeep Paulraj
Add ARM Relocation Support Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-12-17DaVinci: Config cleanupSandeep Paulraj
Some DaVinci boards are using flags that are no longer valid So remove them. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-09-19Remove support for CONFIG_HAS_UID and "forceenv" commandWolfgang Denk
This (undocumented) concept was only in use for the MVSMR and davinci_schmoogie Sergey Kubushyn <ksi@koi8.net> boards. Drop it for now. If really needed, it should be reimplemented later in the context of the new environment command set. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andre Schwarz <andre.schwarz@matrix-vision.de> Cc: Sergey Kubushyn <ksi@koi8.net> Acked-by: Sergey Kubushyn <ksi@koi8.net>
2010-06-22DaVinci: EMAC: Get EMAC_MDIO_PHY_NUM from config filesPrakash PM
Currently EMAC_MDIO_PHY_NUM is defined as 1 in emac_defs.h. Because of this, EMAC does not work on EVMs which do not have phy connected at 1. Moving the macro to board config file makes this configurable depending on where the phy is connected on the MDIO bus. This patch fixes the board reset issue observed during network access on DM365EVM. EMAC driver was assuming EMAC_MDIO_PHY_NUM as 1 but it is 0 on DM365EVM. This patch is verified on da830/omap-l137, dm365 and dm644x evms. Signed-off-by: Prakash PM <prakash.pm@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-01-04Davinci: Configurable NAND chip selectsNick Thompson
Davinci: Configurable NAND chip selects Add a CONFIG_SYS_NAND_CS setting to all davinci configs and use it to setup the NAND controller in the davinci_nand mtd driver. Signed-off-by: Nick Thompson <nick.thompson@gefanuc.com>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-10-13TI DaVinci: Remove references to SZ_xxSandeep Paulraj
This patch removes the asm/sizes.h header file from being included in the DaVinci SOC configs. References to SZ_xx have been replaced by appropriate bit shifted values. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com> Acked-by: Wolfgang Denk <wd@denx.de>
2009-07-18NAND: Part 2: Fix warning Please define CONFIG_SYS_64BIT_VSPRINTF...Wolfgang Denk
Commit 8d2effea added a warning for configurations that use NAND without defining the (then necessary) CONFIG_SYS_64BIT_VSPRINTF but failed to fix the affected boards. This patch covers the non-PPC boards that were missed in the previous patch (commit 170c1972). Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-15Switched davinci_emac Ethernet driver to use newer APIBen Warren
Added CONFIG_NET_MULTI to all Davinci boards Removed all calls to Davinci network driver from board code Added cpu_eth_init() to cpu/arm926ejs/cpu.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-12davinci: display correct clock infoDavid Brownell
Move the clock-rate dumping code into the cpu/.../davinci area where it should have been, enabled by CONFIG_DISPLAY_CPUINFO, updating the format and showing the DSP clock (where relevant). Switch boards to use the cpuinfo() hook for this stuff. Remove a few now-obsolete PLL #defines. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-06-12davinci: split out some dm644x-specific bits from pscDavid Brownell
Split out DaVinci DM6446-specific bits from more generic bits: - Add a CONFIG_SOC_DM644X. All current boards use DM6446 chips; DM6443 and DM6441 chips differ in available peripherals. - Move most DM644X-specific bits from psc.c to a new dm644x.c file, which is conditionally built. It provides device-specific setup. Plus minor coding style and comment updates with respect to the PSC. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-04-24minor DaVinci clock cleanupDavid Brownell
Minor cleanup to clock-related defines for DaVinci DM6446 boards: - CONFIG_SYS_CLK_FREQ is unused; remove it. - CONFIG_SYS_NS16550_CLK must be the same as CONFIG_SYS_HZ_CLOCK On DM6446 both of those peripheral clocks actually come from the same source, the primary oscillator. Having them use the same symbol avoids bugs in the clone'n'modify development cycle. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-04-16fix DaVinci NS16550_REG_SIZE regressionDavid Brownell
Update the DaVinci DM6446 boards to use the new convention for CONFIG_SYS_NS16550_REG_SIZE ... the size hasn't changed from the original 4 bytes, but these chips are little-endian. (Resolves a regression added recently by the include/ns16550.h patch to "Unify structure declaration for registers". The code previously worked just fine because the registers were accessed as host-endian words, not as bytes.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-03-30davinci: move nand driver to drivers/mtd/nandJean-Christophe PLAGNIOL-VILLARD
2009-01-23NAND: rename NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPSWolfgang Grandegger
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and changes the default from 8 to 1 for the legacy and the new MTD NAND layer. This allows to remove all NAND_MAX_CHIPS definitions in the board config files because none of the boards use multi chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440 define #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE but that's bogus and did not work anyhow. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-09-10rename CFG_ENV_IS_IN_NAND in CONFIG_ENV_IS_IN_NANDJean-Christophe PLAGNIOL-VILLARD
2008-04-11Revert merge of git://www.denx.de/git/u-boot-arm, commit 62479b18:Wolfgang Denk
Reverting became necessary after it turned out that the patches in the u-boot-arm repo were modified, and in some cases corrupted. This reverts the following commits: 066bebd6353e33af3adefc3404560871699e9961 7a837b7310166ae8fc8b8d66d7ef01b60a80f9d6 c88ae20580b2b01487b4cdcc8b2a113f551aee36 a147e56f03871bba4f05058d5e04ce7deb010b04 d6674e0e2a6a1f033945f78838566210d3f28c95 8c8463cce44d849e37744749b32d38e1dfb12e50 c98b47ad24b2d91f41c09a3d62d7f70ad84f4b7d 8bf69d81782619187933a605f1a95ee1d069478d 8c16cb0d3b971f46fbe77c072664c0f2dcd4471d a574a73852a527779234e73e17e7597fd8128882 1377b5583a48021d983e1fd565f7d40c89e84d63 1704dc20917b4f71e373e2c888497ee666d40380 Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-30Removes all board specific code from the arch. part for DM644x (DaVinci) boardsPieter Voorthuijsen
Signed-off-by: Pieter Voorthuijsen <pv@prodrive.nl>
2007-08-10[ARM] TI DaVinci support, hopefully finalSergey Kubushyn
Add support for the following DaVinci boards: - DV_EVM - SCHMOOGIE - SONATA Changes: - Split into separate board directories - Removed changes to MTD_DEBUG (or whatever it's called) - New CONFIG_CMD party line followed - Some cosmetic fixes, cleanup etc. - Patches against the latest U-Boot tree as of now. - Fixed CONFIG_CMD_NET in net files. - Fixed CONFIG_CMD_EEPROM for schmoogie. - Made sure it compiles and works (forceenv() link problem) on SCHMOOGIE and DV_EVM. Can't check if it works on SONATA, don't have a board any more, but it at least compiles. Here is an excerpt from session log on SCHMOOGIE... U-Boot 1.2.0-g6c33c785-dirty (Aug 7 2007 - 13:07:17) DRAM: 128 MB NAND: 128 MiB In: serial Out: serial Err: serial ARM Clock : 297MHz DDR Clock : 162MHz ETH PHY : DP83848 @ 0x01 U-Boot > iprobe Valid chip addresses: 1B 38 3A 3D 3F 50 5D 6F U-Boot > ping 192.168.253.10 host 192.168.253.10 is alive U-Boot > Signed-off-by: Sergey Kubushyn <ksi@koi8.net> Acked-by: Dirk Behme <dirk.behme@gmail.com> Acked-by: Zach Sadecki <Zach.Sadecki@ripcode.com> Acked-by: Stefan Roese <sr@denx.de>
