Adding the CONFIG_SYS_64BIT_VSPRINTF in the DVEVM config.
Without this option enabled while performing NAND operations we will get
wrong diagnostic messages.
Example if the MTD NAND driver find a bad block while erasing from
a certain address, it will say bad block skipped at 0x00000000.
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
The Default mode that is built for the Davinci DVEVM happens
to be the NOR mode.
When we want to build for the NAND mode, we get a compilation
error. This is overcome by defining the CONFIG_MTD_DEVICE
flag in the NAND mode.
The image built for NAND mode was successfully tested on the
DaVinci DM6446 EVM.
This patch removes the asm/sizes.h header file from being
included in the DaVinci SOC configs.
References to SZ_xx have been replaced by appropriate
bit shifted values.
Acked-by: Wolfgang Denk <wd@denx.de>
Added CONFIG_NET_MULTI to all Davinci boards
Removed all calls to Davinci network driver from board code
Added cpu_eth_init() to cpu/arm926ejs/cpu.c
This updates the optional (non-default!) NAND support for the
DaVinci DM6446 EVM:
- include MTD partitioning, defaulting to what Linux uses
- use a flash-based BBT, which among other things speeds bootup
This matches code that's now queued for mainline Linux, and might
even merge in an upcoming 2.6.30-rc; and the MTIDS are set up so
that the U-Boot $mtdparts environment variable can be passed as-is
on the kernel command line as a cmdlinepart override.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Move the clock-rate dumping code into the cpu/.../davinci area
where it should have been, enabled by CONFIG_DISPLAY_CPUINFO,
updating the format and showing the DSP clock (where relevant).
Switch boards to use the cpuinfo() hook for this stuff.
Remove a few now-obsolete PLL #defines.
Split out DaVinci DM6446-specific bits from more generic bits:
- Add a CONFIG_SOC_DM644X. All current boards use DM6446 chips;
DM6443 and DM6441 chips differ in available peripherals.
- Move most DM644X-specific bits from psc.c to a new dm644x.c file,
which is conditionally built. It provides device-specific setup.
Plus minor coding style and comment updates with respect to the PSC.
Minor cleanup to clock-related defines for DaVinci DM6446 boards:
- CONFIG_SYS_CLK_FREQ is unused; remove it.
- CONFIG_SYS_NS16550_CLK must be the same as CONFIG_SYS_HZ_CLOCK
On DM6446 both of those peripheral clocks actually come from the
same source, the primary oscillator. Having them use the same
symbol avoids bugs in the clone'n'modify development cycle.
Update the DaVinci DM6446 boards to use the new convention
for CONFIG_SYS_NS16550_REG_SIZE ... the size hasn't changed
from the original 4 bytes, but these chips are little-endian.
(Resolves a regression added recently by the include/ns16550.h
patch to "Unify structure declaration for registers". The code
previously worked just fine because the registers were accessed
as host-endian words, not as bytes.)
Enabling USB MSC support for DM6446 (TI DaVinci) platform in the
configuration file.
Signed-off-by: Ravi Babu <ravibabu@ti.com>
Signed-off-by: Swaminathan S <swami.iyer@ti.com>
Signed-off-by: Thomas Abraham <t-abraham@ti.com>
Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and
changes the default from 8 to 1 for the legacy and the new MTD
NAND layer. This allows to remove all NAND_MAX_CHIPS definitions
in the board config files because none of the boards use multi
chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440
define
#define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE
but that's bogus and did not work anyhow.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
rename CFG_FLASH_CFI_DRIVER to CONFIG_FLASH_CFI_DRIVER
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Reverting became necessary after it turned out that the patches in
the u-boot-arm repo were modified, and in some cases corrupted.
This reverts the following commits:
066bebd6353e33af3adefc3404560871699e9961
7a837b7310166ae8fc8b8d66d7ef01b60a80f9d6
c88ae20580b2b01487b4cdcc8b2a113f551aee36
a147e56f03871bba4f05058d5e04ce7deb010b04
d6674e0e2a6a1f033945f78838566210d3f28c95
8c8463cce44d849e37744749b32d38e1dfb12e50
c98b47ad24b2d91f41c09a3d62d7f70ad84f4b7d
8bf69d81782619187933a605f1a95ee1d069478d
8c16cb0d3b971f46fbe77c072664c0f2dcd4471d
a574a73852a527779234e73e17e7597fd8128882
1377b5583a48021d983e1fd565f7d40c89e84d63
1704dc20917b4f71e373e2c888497ee666d40380
Signed-off-by: Pieter Voorthuijsen <pv@prodrive.nl>
Add support for the following DaVinci boards:
- DV_EVM
- SCHMOOGIE
- SONATA
Changes:
- Split into separate board directories
- Removed changes to MTD_DEBUG (or whatever it's called)
- New CONFIG_CMD party line followed
- Some cosmetic fixes, cleanup etc.
- Patches against the latest U-Boot tree as of now.
- Fixed CONFIG_CMD_NET in net files.
- Fixed CONFIG_CMD_EEPROM for schmoogie.
- Made sure it compiles and works (forceenv() link problem) on SCHMOOGIE and
DV_EVM. Can't check if it works on SONATA, don't have a board any more,
but it at least compiles.
Here is an excerpt from session log on SCHMOOGIE...
U-Boot 1.2.0-g6c33c785-dirty (Aug 7 2007 - 13:07:17)
DRAM: 128 MB
NAND: 128 MiB
In: serial
Out: serial
Err: serial
ARM Clock : 297MHz
DDR Clock : 162MHz
ETH PHY : DP83848 @ 0x01
U-Boot > iprobe
Valid chip addresses: 1B 38 3A 3D 3F 50 5D 6F
U-Boot > ping 192.168.253.10
host 192.168.253.10 is alive
U-Boot >
Signed-off-by: Sergey Kubushyn <ksi@koi8.net>
Acked-by: Dirk Behme <dirk.behme@gmail.com>
Acked-by: Zach Sadecki <Zach.Sadecki@ripcode.com>
