path: root/include/configs/davinci_dm6467evm.h
2013-08-19configs: Remove unused CONFIG_BOOTP_DEFAULTTom Rini
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-02-27dm6467Tevm: Use a common configuration file for davinci_dm6467evm and ↵prabhakar.csengg@gmail.com
davinci_dm6467Tevm In commit 2d575e46859dd9127a9cec731ace77523e6ea2ab a separate header file was introduced for the DM6467T EVM, include/configs/davinci_dm6467Tevm.h. The substantial difference between the davinci_dm6467evm and the davinci_dm6467Tevm configuration is a single bit in the hardware revision that is passed to the Linux kernel and davinci_dm6467evm has REFCLK_FREQ = 27000000 where as davinci_dm6467Tevm.h has a REFCLK_FREQ = 33000000. This patch removes include/configs/davinci_dm6467Tevm.h. Instead the include/configs/davinci_dm6467evm.h configuration is used for DM6467T EVMs and renamed CFG_REFCLK_FREQ to CONFIG_REFCLK_FREQ and CONFIG_REFCLK_FREQ is defined in boards.cfg. Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-02-12davinci: add support for printing clock frequencyHadli, Manjunath
add support for printing various clock frequency info found in SOC such as ARM core frequency, DSP core frequency and DDR frequency as part of bdinfo command. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com>
2012-02-12davinci: remove macro CONFIG_DISPLAY_CPUINFOHadli, Manjunath
remove the macro CONFIG_DISPLAY_CPUINFO as it is no longer required. This is because clock info will be printed as part 'bdinfo' command and also remove support print_cpuinfo() as it will no longer be called. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com>
2011-11-08dm646x: pass board revision info to kernelManjunath Hadli
add a function in board file to pass board revision info to kernel. Revision number 0 and 1 are passed in case of DM6467 and DM6467T respectively. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUMManjunath Hadli
remove macro CONFIG_EMAC_MDIO_PHY_NUM and depending macro EMAC_MDIO_PHY_NUM as they are no longer needed with the support for more than 1 PHYs in davinci emac driver. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-02-02DaVinci DM6467: Enhance board SupportSandeep Paulraj
Support for DM6467 was incomplete and the build failed as well. Patches were sent to the list but have not been added. This enhances the DM6467 support. Some more patches will need to be sent to bring it in line with what is available in internal TI trees Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-12-17DaVinci DM6467: Add ARM Relocation SupportSandeep Paulraj
Add ARM Relocation Support Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-01-04Davinci: Configurable NAND chip selectsNick Thompson
Davinci: Configurable NAND chip selects Add a CONFIG_SYS_NAND_CS setting to all davinci configs and use it to setup the NAND controller in the davinci_nand mtd driver. Signed-off-by: Nick Thompson <nick.thompson@gefanuc.com>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-10-28Coding Style cleanup; update CHANGELOG, prepare -rc1v2009.11-rc1Wolfgang Denk
2009-10-18TI DaVinci DM646x: Adding initial support for DM6467 EVMSandeep Paulraj
This patch adds the initial support for DM6467 EVM. Other features like NET and NAND support will be added as follow up patches. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
