path: root/include/configs/davinci_dm365evm.h
2015-09-11arm: Remove unmaintained davinci boardsSimon Glass
These boards have not been converted to generic board by the deadline. Remove dm355evm, dm355leopard, dm365evm, dm6467evm, dvevm, ea20, schmoogie, sffsdr, sonata. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05usb: musb-new: CONFIG_MUSB prefix replacement with CONFIG_USB_MUSBPaul Kocialkowski
USB-related options are usually prefixed with CONFIG_USB and platform-specific adaptation for the MUSB controller already have a CONFIG_USB_MUSB prefix, so this switches all MUSB-related options to a CONFIG_USB_MUSB prefix, for consistency. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2014-11-20ARM: remove CONFIG_ARM926EJS definesMasahiro Yamada
CONFIG_CPU_ARM926EJS was introduced into Kconfig by commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs). This commit removes all the defines of CONFIG_ARM926EJS and replaces the only reference in arch/arm/lib/cache.c with CONFIG_CPU_ARM926EJS. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-17i2c, davinci: convert driver to new mutlibus/mutliadapter frameworkVitaly Andrianov
- add davinci driver to new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Acked-by: Heiko Schocher <hs@denx.de>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-08-19configs: Remove unused CONFIG_BOOTP_DEFAULTTom Rini
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-02-12davinci: add support for printing clock frequencyHadli, Manjunath
add support for printing various clock frequency info found in SOC such as ARM core frequency, DSP core frequency and DDR frequency as part of bdinfo command. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com>
2011-10-27davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUMManjunath Hadli
remove macro CONFIG_EMAC_MDIO_PHY_NUM and depending macro EMAC_MDIO_PHY_NUM as they are no longer needed with the support for more than 1 PHYs in davinci emac driver. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27dm36x: revert cache disable patchManjunath Hadli
revert commit 98c19aff9524e1d0dd6bf39bf7bde5644f121feb as the disabling of cache need not be done explicitly. Subsequent patches to new cache management framework has fixed it. EMAC issue with cache coherency still exists when cahces are enabled. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04dm365: modify boot prompt from dm365 to dm36xRajashekhara, Sudhakar
Newer version for DM365 silicon support higher speeds and is called DM368. Modify the bootprompt string DM365 to DM36x. Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04dm365: disable cache usage due to coherency issuesNagabhushana Netagunte
there are cache coherency issues when using the DAVINCI Ethernet driver, hence caches cant be used for d365 u-boot. As per new cache management framework,if the caches are not used in u-boot, it needs to be explicitly indicated through macros in config file. CACHE disable is indicated by the following macro definitions in config file, 1. CONFIG_SYS_ICACHE_OFF 2. CONFIG_SYS_DCACHE_OFF 3. CONFIG_SYS_L2CACHE_OFF Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-02-02DaVinci DM365: Adding MMC/SD support for DM365 EVMSandeep Paulraj
The patch adds support for MMC/SD in the DM365 EVM Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-28DaVinci DM365: Fix for ARM Relocation supportSandeep Paulraj
Fix for ARM Relocation support Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-06-22DaVinci: EMAC: Get EMAC_MDIO_PHY_NUM from config filesPrakash PM
Currently EMAC_MDIO_PHY_NUM is defined as 1 in emac_defs.h. Because of this, EMAC does not work on EVMs which do not have phy connected at 1. Moving the macro to board config file makes this configurable depending on where the phy is connected on the MDIO bus. This patch fixes the board reset issue observed during network access on DM365EVM. EMAC driver was assuming EMAC_MDIO_PHY_NUM as 1 but it is 0 on DM365EVM. This patch is verified on da830/omap-l137, dm365 and dm644x evms. Signed-off-by: Prakash PM <prakash.pm@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-02-03musb: Add host support for DM365 EVMPrathap Srinivas
Add support for musb host on DM365 EVM. Signed-off-by: Prathap Srinivas <msprathap@ti.com>
2010-01-04Davinci: Configurable NAND chip selectsNick Thompson
Davinci: Configurable NAND chip selects Add a CONFIG_SYS_NAND_CS setting to all davinci configs and use it to setup the NAND controller in the davinci_nand mtd driver. Signed-off-by: Nick Thompson <nick.thompson@gefanuc.com>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-10-24TI DaVinci: Adding Copyright for DM365 EVMSandeep Paulraj
Forgot to add Copyright while submitting the patch. This patch adds the copyright. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-10-18TI DaVinci DM365: Add Config option for 64 bit SupportSandeep Paulraj
Adding the CONFIG_SYS_64BIT_VSPRINTF in the DM365 EVM config. Without this option enabled while performing NAND operations we will get wrong diagnostic messages. Example if the MTD NAND driver find a bad block while erasing from a certain address, it will say bad block skipped at 0x00000000. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-10-13TI: DaVinci DM365: Minor config cleanupSandeep Paulraj
The DM365 config was using the 'CONFIG_CMD_SAVEENV' flag. This is already included when we include the config_cmd_default.h header file. So this flag is removed. Also another flag to enable NAND functions was being enabled incorrectly. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-10-13TI DaVinci: Remove references to SZ_xxSandeep Paulraj
This patch removes the asm/sizes.h header file from being included in the DaVinci SOC configs. References to SZ_xx have been replaced by appropriate bit shifted values. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com> Acked-by: Wolfgang Denk <wd@denx.de>
2009-09-05ARM: DaVinci: Adding Support for DaVinci DM365 EVMSandeep Paulraj
This patch adds support for the DM365 EVM. It has been tested on a DM365 EVM. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
