path: root/include/configs/dart_6ul.h
2020-05-18common: Drop linux/stringify.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-12defconfigs: Migrate CONFIG_SYS_REDUNDAND_ENVIRONMENTTom Rini
Move this symbol to Kconfig. As part of this we can drop a UBI-specific symbol that was a stop-gap for not having this particular symbol in Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-23Convert CONFIG_FSL_USDHC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_FSL_USDHC Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-25imx: Add variscite DART-6UL Evaluation KitParthiban Nallathambi
Port for the DART-6UL Evaluation Kit SBC. Based on the variscite DART-6UL iMX6ULL SoM. CPU: Freescale i.MX6ULL rev1.1 900 MHz (running at 396 MHz) CPU: Commercial temperature grade (0C to 95C) at 43C Reset cause: POR Model: Variscite DART-6UL Evaluation Kit Board: Variscite DART-6UL Evaluation Kit DRAM: 512 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 In: serial@02020000 Out: serial@02020000 Err: serial@02020000 Net: FEC0 Working: - Eth0 - i2c - MMC/SD - eMMC - USB host - UART 1 Note: LCDIF porting needs DM_VIDEO https://lists.denx.de/pipermail/u-boot/2019-April/365506.html Signed-off-by: Parthiban Nallathambi <parthitce@gmail.com>
