path: root/include/configs/dalmore.h
2015-03-04ARM: tegra: move common config defines centrallyStephen Warren
All boards need CONFIG_BOARD_EARLY_INIT_F, and many actively need CONFIG_BOARD_LATE_INIT. Move both of these into tegra-common.h so that board config headers don't need to repeatedly define them. Later commits will add new code in board_late_init() which applies to all boards, so CONFIG_BOARD_LATE_INIT should be enabled for all Tegra boards. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-11dm: i2c: tegra: Convert to driver modelSimon Glass
This converts all Tegra boards over to use driver model for I2C. The driver is adjusted to use driver model and the following obsolete CONFIGs are removed: - CONFIG_SYS_I2C_INIT_BOARD - CONFIG_I2C_MULTI_BUS - CONFIG_SYS_MAX_I2C_BUS - CONFIG_SYS_I2C_SPEED - CONFIG_SYS_I2C This has been tested on: - trimslice (no I2C) - beaver - Jetson-TK1 It has not been tested on Tegra 114 as I don't have that board. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-03-04sizes.h - consolidate for all architecturesAlexey Brodkin
Copied from Linux sources "include/linux/sizes.h" commit 413541dd66d51f791a0b169d9b9014e4f56be13c Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com> Acked-by: Stefan Roese <sr@denx.de> [trini: Add bcm Kona platforms to the patch] Signed-off-by: Tom Rini <trini@ti.com>
2013-08-19ARM: tegra: Enable data cache on DalmoreThierry Reding
Disabling the data cache is no longer required to boot Dalmore, so enable it. This results in notably better performance when loading and booting the Linux kernel. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-07-23tegra: i2c: Enable new CONFIG_SYS_I2C frameworkSimon Glass
This enables CONFIG_SYS_I2C on Tegra, updating existing boards and the Tegra i2c driver to support this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heiko Schocher <hs@denx.de>
2013-07-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and serial. Conflicts: arch/arm/dts/exynos5250.dtsi Signed-off-by: Tom Rini <trini@ti.com>
2013-07-11Tegra: Config: Enable Tegra30/Tegra114 USB functionJim Lin
Add USB EHCI, storage and network support. Tested on Tegra30 Cardhu, and Tegra114 Dalmore platforms. All works well. Signed-off-by: Jim Lin <jilin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-06-13ARM: tegra: make use of negative ENV_OFFSET on NVIDIA boardsStephen Warren
Use a negative value of CONFIG_ENV_OFFSET for all NVIDIA reference boards that store the U-Boot environment in the 2nd eMMC boot partition. This makes U-Boot agnostic to the size of the eMMC boot partition, which can vary depending on which eMMC device was actually stuffed into the board. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-03-25Tegra114: MMC: Enable DT MMC driver support for Tegra114 Dalmore boardsTom Warren
Tested on my Dalmore E1611 board, eMMC and SD-Card work fine, can load a kernel off of an SD card OK, card detect works, and the env is now stored in eMMC (end of the 2nd 'boot' sector, same as Tegra20/30). Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-25tegra114: dalmore: config: enable SPIAllen Martin
Turn on SPI in dalmore config file Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra114: I2C: Enable I2C driver on Dalmore E1611 eval boardTom Warren
Tested all 5 'buses', i2c probe enumerates device addresses on bus 0, 1 and 2. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Laxman Dewangan <ldewangan@nvidia.com>
2013-02-11Tegra114: Add/enable Dalmore build (T114 reference board)Tom Warren
This build is stripped down. It boots to the command prompt. GPIO is the only peripheral supported. Others TBD. Signed-off-by: Tom Warren <twarren@nvidia.com>
