Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
We provide a default table of { 9600, 19200, 38400, 57600, 115200 }
in <config_fallbacks.h> which mkconfig places after <configs/...h> in
the generated config file. This is used when a board has not set its
own table.
This patch moves hawkboard to the new spl infrastructure from the
older nand_spl one.
Removed the hawkboard_nand_config build option -- The spl code now
gets compiled with hawkboard_config, after building the main u-boot
image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard
to reflect the same.
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
Cc: Christian Riesch <christian.riesch@omicron.at>
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Cc: Tom Rini <trini@ti.com>
Acked-by: Christian Riesch <christian.riesch@omicron.at>
The V bit of the c1 register of CP15 should not be cleared on DA850
SoCs since they have no valid memory at 0x00000000. This patch
introduces a configuration option CONFIG_SYS_EXCEPTION_VECTORS_HIGH
that allows setting the correct value for the V bit.
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Reported-by: Sughosh Ganu <urwithsughosh@gmail.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Sughosh Ganu <urwithsughosh@gmail.com>
This patch reverts commit ca4b55800ed74207c35271bf7335a092d4955416
"arm, arm926ejs: always do cpu critical inits" since it impacts all
arm926ejs based configurations and caused problems, e.g., with
the hawkboard.
Instead the patch removes the CONFIG_SKIP_LOWLEVEL_INIT defines
from the board configurations that need low level initialization.
Acked-by: Heiko Schocher <hs@denx.de>
Tested-by: Heiko Schocher <hs@denx.de>
add support for printing various clock frequency info found
in SOC such as ARM core frequency, DSP core frequency and DDR
frequency as part of bdinfo command.
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
This change follows the change by Wolfgang Grandegger (commit 6c869637fef),
which allows to remove useless NAND_MAX_CHIPS definitions in board config
files.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Cc: Wolfgang Grandegger <wg@grandegger.com>
Cc: Scott Wood <scottwood@freescale.com>
This patch removes the defines CONFIG_SYS_ICACHE_OFF,
CONFIG_SYS_DCACHE_OFF, and CONFIG_SYS_L2CACHE_OFF from the board
configuration. These defines are useless since cache is
anyway disabled for the entire architecture since commit
cba4b1809f043bf85c806e5a4e342f62bd5ded45.
Cc: Sandeep Paulraj <s-paulraj@ti.com>
The boards in board/davinci/da8xxevm/ define pinmux_config[] vectors
that contain pinmux configurations for emac, uarts, memory controllers...
In an earlier patch such pinmux configurations were added to the arch
tree. This patch makes the da850evm use these definitions instead of
defining its own.
Cc: Mike Frysinger <vapier@gentoo.org>
remove macro CONFIG_EMAC_MDIO_PHY_NUM and depending macro EMAC_MDIO_PHY_NUM
as they are no longer needed with the support for more than 1 PHYs in davinci
emac driver.
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Since commit f1d2b313c9eb6808d30c16a9eb5251240452a56c the serial
port of the da850evm is accessed before the UART2 peripheral of
the SoC is powered on in the function board_init() in
board/davinci/da8xxevm/da850evm.c.
When u-boot is used in conjunction with the UBL (user boot loader, see
doc/README.davinci) on this board, the UART2 peripheral is already
turned on by UBL at the time u-boot is started. Hence, the wrong
initialization sequence is not noticed by most users. However, if UBL is not
used, u-boot must power on the peripheral before using it.
This patch adds a board_early_init_f() function for the LPSC
configuration to the da850evm board configuration.
Cc: Ben Gardiner <bengardiner@nanometrics.ca>
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
The AM18xx EVM contains winbond SPI flash instead of ST SPI flash in
comparison with logic PD da850/omap-l138 EVM. So enable configuration
to look for winbond flash.
Signed-off-by: Manjunathappa, Prakash <prakash.pm@ti.com>
Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com>
add support for DSP wake-up by default on DA850/OMAP-L138
during board initialization. Enable hwconfig environment and added
extra env setting through CONFIG_EXTRA_ENV_SETTINGS.
To prevent DSP from being woken up,set the environment variable as,
set hwconfig "dsp:wake=no"
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Modify U-Boot prompt string from "DA850-evm >" to "U-Boot >".
Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Add pin-mux support for NOR in board file and correspanding
macros to use NOR boot mode in configuration file.
there are cache coherency issues when using the DAVINCI Ethernet driver,
hence caches cant be used for da850 u-boot. As per new cache management
framework,if the caches are not used in u-boot, it needs to be explicitly
indicated through macros in config file. CACHE disable is indicated by
the following macro definitions in config file,
1. CONFIG_SYS_ICACHE_OFF
2. CONFIG_SYS_DCACHE_OFF
3. CONFIG_SYS_L2CACHE_OFF
This patch is a port of the work by Sudhakar Rajeshekhara in commit
ab3effbcad8851cc65dc5241a01c064d2030a3b2 of
git://arago-project.org/git/people/sandeep/u-boot-davinci.git.
The da850 UI board has on it an RMII PHY which can be used if the MDC line
to the MII PHY on the baseboard is disabled and the RMII PHY is enabled by
configuring the values of some GPIO pins on the IO expander of the UI board.
This patch implements disabling that line via GPIO2[6], configuring the UI
board's IO expander and setting only the pinmux settings that are needed for
RMII operation.
Tested on da850evm by adding a define for CONFIG_DRIVER_TI_EMAC_USE_RMII.
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
CC: Sandeep Paulraj <s-paulraj@ti.com>
CC: Ben Warren <biggerbadderben@gmail.com>
CC: Mike Frysinger <vapier@gentoo.org>
CC: Sughosh Ganu <urwithsughosh@gmail.com>
The patch was already posted to the arago project,
but not yet to mainline. It allows to save environment into
the spi flash. Tested on LogiPD tmdxl138.
CC: Detlev Zundev <dzu@denx.de>
CC: Ben Gardiner <bengardiner@nanometrics.ca>
Some boar config files defined DEF_BOOTM but this was not used
anywhere in the code. Remove this bogus define.
The TI DA850/OMAP-L138/AM18x EVM can be populated with devices
having different maximum allowed CPU clock rating.
The maximum clock the chip can support can only be determined from
the label on the package (not software readable).
Introduce a method to pass the maximum allowed clock rate information
to kernel using ATAG_REVISION. The kernel uses this information to
determine the maximum cpu clock rate reachable using cpufreq.
Note that U-Boot itself does not set the CPU clock rate. The CPU
clock is setup by a primary bootloader ("UBL"). The rate setup by
UBL could be different from the maximum clock rate supported by the
device.
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the
now unnecessary config.mk file.
Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
This patch fixes the LINUX_BOOT_PARAM_ADDR define to be based off of
PHYS_SDRAM_1 instead of CONFIG_SYS_MEMTEST_START. On da830 they are the same
thing but on da850 the CONFIG_SYS_MEMSTART define is offset from the
PHYS_SDRAM_1 start.
Without this patch it is not possible to boot linux on da850 -- bootm hangs
at "Uncompressing Linux... done, booting the kernel."
The current da850evm support in u-boot/master omits any use of
the davinci EMAC. This patch adds basic support for the EMAC using
the MII PHY found on the baseboard of the EVM. The MAC address is
read from the environment variable 'ethadd'. Note that this is
different from the da850evm support in the u-boot omapl1 tree
where the MAC address is read from SPI flash.
CC: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
This patch enables also the mtdpart, ubi and ubifs commands when NAND support
is enabled.
Signed-off-by: Ben Gardiner<bengardiner@nanometrics.ca>
To: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
The current da850evm config is missing the pieces for NAND support that can be
found in Sandeep's u-boot-davinci tree [1].
This patch adds NAND support in the spirit of the support in the u-boot-davinci
tree where NAND support for the da850evm can be enabled by putting a single
'#define CONFIG_USE_NAND' at the top of the include/configs/da850evm.h file.
[1] http://arago-project.org/git/people/?p=sandeep/u-boot-davinci.git;a=tree
There were some #undef's of CONFIG_SYS_ARM_WITHOUT_RELOC added to a few board
configs as part of the arm relocation series; but these are not needed now as we
do not #undef what is not #defined in the first place.
CC: Heiko Schocher <hs@denx.de>
Split the existing dram_init for da8xx when ARM reloc is enabled, like the
changes to arch/arm/cpu/arm926ejs/orion5x/dram.c in
0f234d263b17ccf1b8fd776eb8c15b7cdb27a887 by Heiko Schocher <hs@denx.de>.
Without these changes gd->ram_size is '0' which leads to incorrect relocation
when CONFIG_SYS_ARM_WITHOUT_RELOC is defined and the board does not boot.
We use get_ram_size to dynamically calculate the available RAM because it runs
on different board version with different ram, as suggested by Heiko in private
communication.
Tested on a da850evm with 128M of DDR2 installed; with both
CONFIG_SYS_ARM_WITHOUT_RELOC defined and undefined.
Reviewed-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Change the implementation for arm926 to relocate the code to
an arbitrary address in RAM.
Adapt the TX25 (i.MX25), magnesium board to test the changes.
On the tx25 board TEXT_BASE is set to the final relocation
address to prevent one more copying of u-boot code
when relocating. More info see:
doc/README.arm-relocation
da850 board:
Portions of this work were supported by funding from
the CE Linux Forum.
Provides initial support for TI OMAP-L138/DA850 SoC devices on
a Logic PD EVM board.
Provides:
Initial boot and configuration.
Support for i2c.
UART support (console).
Acked-by: Ben Gardiner <bengardiner@nanometrics.ca>
Reviewed-by: Wolfgang Denk <wd@denx.de>
