path: root/include/configs/da850evm.h
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-01-05da850evm: Use generic board and libfdt, fix size for SPI flashPeter Howard
Add defines to use CONFIG_SYS_GENERIC_BOARD and CONFIG_OF_LIBFDT. Semi-separate to this: the size of the image for the da850evm has increased to the point that the size in da850evm.h and the offset for the environment in SPI flash no longer work. They are modified to account for the larger image size. Signed-off-by: Peter Howard <phoward@gme.net.au> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-11-20ARM: remove CONFIG_ARM926EJS definesMasahiro Yamada
CONFIG_CPU_ARM926EJS was introduced into Kconfig by commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs). This commit removes all the defines of CONFIG_ARM926EJS and replaces the only reference in arch/arm/lib/cache.c with CONFIG_CPU_ARM926EJS. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24spl: replace CONFIG_SPL_SPI_* with CONFIG_SF_DEFAULT_*Nikita Kiryanov
Currently, CONFIG_SPL_SPI_* #defines are used for controlling SPI boot in SPL. These #defines do not allow the user to select SPI mode for the SPI flash (there's no CONFIG_SPL_SPI_MODE, so the SPI mode is hardcoded in spi_spl_load.c), and duplicate information already provided by CONFIG_SF_DEFAULT_* #defines. Kill CONFIG_SPL_SPI_*, and use CONFIG_SF_DEFAULT_* instead. Cc: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Bo Shen <voice.shen@atmel.com> Cc: Hannes Petermaier <hannes.petermaier@br-automation.com> Cc: Michal Simek <monstr@monstr.eu> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-05-13arm, davinci: Use CONFIG_SPL_PAD_TO for padding the SPL in an ais imageChristian Riesch
The commits commit b7b5f1a16ca66dfdd817e7339f0e263a5b9f2758 Author: Albert ARIBAUD <albert.u.boot@aribaud.net> da850evm, da850_am18xxevm: convert to CONFIG_SPL_MAX_FOOTPRINT and commit e7497891e34efe5cb2b3a3dc7c6c096c012ede28 Author: Albert ARIBAUD <albert.u.boot@aribaud.net> cam_enc_4xx: convert to CONFIG_SPL_MAX_FOOTPRINT replaced CONFIG_SPL_MAX_SIZE by CONFIG_SPL_MAX_FOOTPRINT. However, CONFIG_SPL_MAX_SIZE is used in the Makefile for padding the SPL when preparing an u-boot.ais image. By removing CONFIG_SPL_MAX_SIZE said commits broke the ais image of the da850evm and cam_enc_4xx configurations. This patch converts the u-boot.ais target to use CONFIG_SPL_PAD_TO instead of CONFIG_SPL_MAX_SIZE for padding the SPL and adds a #define CONFIG_SPL_PAD_TO where it is required. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Reported-by: Tom Taylor <ttaylor.tampa@gmail.com> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-04-17i2c, davinci: convert driver to new mutlibus/mutliadapter frameworkVitaly Andrianov
- add davinci driver to new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Acked-by: Heiko Schocher <hs@denx.de>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-10-08da850evm.h: Always set CONFIG_CMD_SF, move to by CONFIG_SPI_FLASHTom Rini
When we have CONFIG_SPI_FLASH set we now require CONFIG_CMD_SF. Signed-off-by: Tom Rini <trini@ti.com>
2013-08-19configs: Remove unused CONFIG_BOOTP_DEFAULTTom Rini
2013-05-10davinci: handle CONFIG_SYS_CLE_MASK and CONFIG_SYS_ALE_MASKEric Benard
these variables are curently defined in several config files but the driver doesn't use them and defaults to hardcoded values in nand_defs.h It's interesting to be able to change this hardcoded valude when the hardware is not using the default adress signals to drive ALE and CLE and two configuration defines already exist for this purpose so use them. Signed-off-by: Eric BĂ©nard <eric@eukrea.com>
2013-04-14da850evm, da850_am18xxevm: convert to CONFIG_SPL_MAX_FOOTPRINTAlbert ARIBAUD
This target wants to check full SPL size, BSS included. Remove CONFIG_SPL_MAX_SIZE definition and instead define CONFIG_SPL_MAX_FOOTPRINT. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-11-26spl/nand: introduce CONFIG_SPL_NAND_DRIVERS, _BASE, and _ECC.Scott Wood
Some small SPLs do not use nand_base.c, and a subset of those also require a special driver. Some SPLs need software ECC but others can't fit it. All existing boards that specify CONFIG_SPL_NAND_SUPPORT have these symbols added to preserve existing behavior. Signed-off-by: Scott Wood <scottwood@freescale.com> -- v2: use positive logic for including bits of NAND, rather than a MINIMAL symbol that excludes things.
2012-09-27ARM: SPL: Convert davinci to CONFIG_SPL_FRAMEWORKTom Rini
- Convert the non-relocation part of board_init_f to spl_board_init, turn on CONFIG_SPL_BOARD_INIT in the configs. - Remove duplicated code. - Add spl_boot_device() that returns the statically chosen boot device. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01da850/omap-l138: add support for direct NOR boot modeLad, Prabhakar
This patch adds support for direct NOR boot mode on da850/omap-l138. Added da850evm_direct_nor entry in boards.cfg to allow to build targets. Tested-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
2012-09-01da850/omap-l138: Add support for NAND SPLLad, Prabhakar
This patch adds configuration required for NAND SP on DA850/OMAP-L138. Tested-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
2012-09-01da850/omap-l138: Add support to read u-boot image from MMC/SDLad, Prabhakar
DA850/OMAP-L138 does not support strict MMC/SD boot mode. SPL will be in SPI flash and U-Boot image will be in MMC/SD card. SPL will do the low level initialization and then loads the u-boot image from MMC/SD card. Define CONFIG_SPL_MMC_LOAD macro in the DA850/OMAP-L138 configuration file to enable this feature. Tested-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
2012-09-01da850/omap-l138: Define SPI specific configs for SPL only when SPI is usedLad, Prabhakar
define SPI specific configs for SPL only when CONFIG_USE_SPIFLASH config is defined Tested-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
2012-09-01da850/omap-l138: Make MMC and NOR support mutually exclusiveRajashekhara, Sudhakar
On Logic PD Rev.3 DA850/OMAP-L138 EVM, NOR and MMC/SD cannot work together. This patch enables the MMC/SD support only when NOR support is disabled. NOR Flash identification works even without this patch, but erase and write will have issues. Tested-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
2012-09-01da850/omap-l138: Add MMC support for DA850/OMAP-L138Lad, Prabhakar
This patch adds support for MMC/SD on DA850/OMAP-L138. Tested-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-02-12Changes to move hawkboard to the new spl infrastructureSughosh Ganu
This patch moves hawkboard to the new spl infrastructure from the older nand_spl one. Removed the hawkboard_nand_config build option -- The spl code now gets compiled with hawkboard_config, after building the main u-boot image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard to reflect the same. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Tom Rini <trini@ti.com> Acked-by: Christian Riesch <christian.riesch@omicron.at>
2012-02-12arm, arm926ejs: Add option CONFIG_SYS_EXCEPTION_VECTORS_HIGHChristian Riesch
The V bit of the c1 register of CP15 should not be cleared on DA850 SoCs since they have no valid memory at 0x00000000. This patch introduces a configuration option CONFIG_SYS_EXCEPTION_VECTORS_HIGH that allows setting the correct value for the V bit. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Reported-by: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Heiko Schocher <hs@denx.de>
2012-02-12arm, arm926ejs: Do cpu critical inits only for boards that require itChristian Riesch
This patch reverts commit ca4b55800ed74207c35271bf7335a092d4955416 "arm, arm926ejs: always do cpu critical inits" since it impacts all arm926ejs based configurations and caused problems, e.g., with the hawkboard. Instead the patch removes the CONFIG_SKIP_LOWLEVEL_INIT defines from the board configurations that need low level initialization. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de> Tested-by: Heiko Schocher <hs@denx.de>
2012-02-12davinci: add support for printing clock frequencyHadli, Manjunath
add support for printing various clock frequency info found in SOC such as ARM core frequency, DSP core frequency and DDR frequency as part of bdinfo command. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com>
2012-01-26NAND: remove NAND_MAX_CHIPS definitionsVladimir Zapolskiy
This change follows the change by Wolfgang Grandegger (commit 6c869637fef), which allows to remove useless NAND_MAX_CHIPS definitions in board config files. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-01-16da850evm: Remove CONFIG_SYS_xxCACHE_OFF definesChristian Riesch
This patch removes the defines CONFIG_SYS_ICACHE_OFF, CONFIG_SYS_DCACHE_OFF, and CONFIG_SYS_L2CACHE_OFF from the board configuration. These defines are useless since cache is anyway disabled for the entire architecture since commit cba4b1809f043bf85c806e5a4e342f62bd5ded45. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Tom Rini <trini@ti.com>
2011-12-24arm, da850evm: Add an SPL for SPI bootChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
2011-12-06arm, da850evm: Use the pinmux configurations defined in the arch treeChristian Riesch
The boards in board/davinci/da8xxevm/ define pinmux_config[] vectors that contain pinmux configurations for emac, uarts, memory controllers... In an earlier patch such pinmux configurations were added to the arch tree. This patch makes the da850evm use these definitions instead of defining its own. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Heiko Schocher <hs@denx.de>
2011-10-27davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUMManjunath Hadli
remove macro CONFIG_EMAC_MDIO_PHY_NUM and depending macro EMAC_MDIO_PHY_NUM as they are no longer needed with the support for more than 1 PHYs in davinci emac driver. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27da850evm: Move LPSC configuration to board_early_init_f()Christian Riesch
Since commit f1d2b313c9eb6808d30c16a9eb5251240452a56c the serial port of the da850evm is accessed before the UART2 peripheral of the SoC is powered on in the function board_init() in board/davinci/da8xxevm/da850evm.c. When u-boot is used in conjunction with the UBL (user boot loader, see doc/README.davinci) on this board, the UART2 peripheral is already turned on by UBL at the time u-boot is started. Hence, the wrong initialization sequence is not noticed by most users. However, if UBL is not used, u-boot must power on the peripheral before using it. This patch adds a board_early_init_f() function for the LPSC configuration to the da850evm board configuration. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Ben Gardiner <bengardiner@nanometrics.ca> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04da850: add support for Spectrum Digital AM18xx EVMManjunathappa, Prakash
The AM18xx EVM contains winbond SPI flash instead of ST SPI flash in comparison with logic PD da850/omap-l138 EVM. So enable configuration to look for winbond flash. Signed-off-by: Manjunathappa, Prakash <prakash.pm@ti.com> Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04da850: add support to wake up DSP during board initNagabhushana Netagunte
add support for DSP wake-up by default on DA850/OMAP-L138 during board initialization. Enable hwconfig environment and added extra env setting through CONFIG_EXTRA_ENV_SETTINGS. To prevent DSP from being woken up,set the environment variable as, set hwconfig "dsp:wake=no" Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
