path: root/include/configs/da830evm.h
2012-02-12davinci: add support for printing clock frequencyHadli, Manjunath
add support for printing various clock frequency info found in SOC such as ARM core frequency, DSP core frequency and DDR frequency as part of bdinfo command. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com>
2012-01-26NAND: remove NAND_MAX_CHIPS definitionsVladimir Zapolskiy
This change follows the change by Wolfgang Grandegger (commit 6c869637fef), which allows to remove useless NAND_MAX_CHIPS definitions in board config files. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-27davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUMManjunath Hadli
remove macro CONFIG_EMAC_MDIO_PHY_NUM and depending macro EMAC_MDIO_PHY_NUM as they are no longer needed with the support for more than 1 PHYs in davinci emac driver. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27da830: add support for NAND boot modeManjunath Hadli
Add support for enabling NAND boot mode in configuration file and add correspanding pinmux support, nand initialize function in board file. The size required for environment variables not more than 10KB the CONFIG_ENV_SIZE is set to 10KB from (512 << 10). Acked-by: Nick Thompson <nick.thompson@ge.com> Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13DA830: Fix Build WarningSandeep Paulraj
This commit fixes a build warning in the DA830 EVM build Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12da830: modify the MEMTEST start and end addressNagabhushana Netagunte
Modify the MEMTEST start and end address. The memtest range was overlapping the CONFIG_SYS_LOAD_ADDR which causes the uImage to be corrupt.Also, modify the size for which mtest is run to 32MB from 16MB. Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12da830: enable SPI flash boot modeNagabhushana Netagunte
Enable SPI flash boot mode in configuration file as default. With the introduction of 456MHz part, SPI operating frequency will increase and at this frequency SPI does not work correctly. Hence reduce the default SPI speed to 30MHz from 50MHz. Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12da830: modify the U-Boot prompt stringNagabhushana Netagunte
Modify U-boot promt string from 'DA830-evm >' to 'U-Boot >' as there are many variants of da830 based boards which have diffrent names such as L137, AM1707 etc. Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-19DaVinci: remove bogus DEF_BOOTM definitionWolfgang Denk
Some boar config files defined DEF_BOOTM but this was not used anywhere in the code. Remove this bogus define. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-19da830: fixup ARM relocation supportNick Thompson
Fixes build breakage in da830evm after commit 97003756249bd790910417eb66f0039bbf06a02c "da8xx: fixup ARM relocation support" The da8xx fixup commit changed da830/da850 common code to make relocation work in da850, but didn't add the required defines to da830evm_config.h resulting in build failure in the common code. This patch adds those defines for da830, but makes no sense without also referring to the commit mentioned above. Signed-off-by: Nick Thompson <nick.thompson@ge.com> Reviewed-by: Ben Gardiner <bengardiner@nanometrics.ca> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-26Remove config.mk for da8xxevm based boards.Sughosh Ganu
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the now unnecessary config.mk file. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
2010-06-22DaVinci: EMAC: Get EMAC_MDIO_PHY_NUM from config filesPrakash PM
Currently EMAC_MDIO_PHY_NUM is defined as 1 in emac_defs.h. Because of this, EMAC does not work on EVMs which do not have phy connected at 1. Moving the macro to board config file makes this configurable depending on where the phy is connected on the MDIO bus. This patch fixes the board reset issue observed during network access on DM365EVM. EMAC driver was assuming EMAC_MDIO_PHY_NUM as 1 but it is 0 on DM365EVM. This patch is verified on da830/omap-l137, dm365 and dm644x evms. Signed-off-by: Prakash PM <prakash.pm@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-03-07da830evm: Add support for TI EMACNick Thompson
Adds support for ethernet networking on the da830evm platform. This platform uses an SoC EMAC interface and a 3 port ethernet switch as a PHY with an RMII interface. The PHY also has a i2c interface for configuring the switch functions. Signed-off-by: Nick Thompson <nick.thompson@ge.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-02-12DA830 EVM: Enable NAND support on Spectrum Digital EVMNick Thompson
The EVM UI extender card has a NAND device. This change will enable saveenv to work with NAND and Linux to be booted using: mtdparts default nboot kernel bootm Signed-off-by: Nick Thompson <nick.thompson@ge.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-01-09DA830: Add usb configAjay Kumar Gupta
Adding USB configuration. Default is set for USB MSC host. Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Signed-off-by: Swaminathan S <swami.iyer@ti.com>
2009-11-27TI DA8xx: Integrate DA830 EVM support into U-BootSekhar Nori
Integrate DA830 EVM support into U-Boot. Provides initial support for TI OMAP-L137/DA830 SoC devices on a Spectrum Digital EVM board. See http://www.spectrumdigital.com/ Signed-off-by: Nick Thompson <nick.thompson@gefanuc.com>
