path: root/include/configs/csb272.h
2007-07-09include/configs/[a-m]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various c* named board config files.Jon Loeliger
2004-03-23* Patch by Pierre Aubert, 18 Mar 2004:wdenk
- Unify video mode handling for Chips & Technologies 69000 Video chip and Silicon Motion SMI 712/710/810 Video chip - Add selection of the video output (CRT or LCD) via 'videoout' environment variable for the Silicon Motion - README update * Patch by Pierre Aubert, 18 Mar 2004: include/common.h typo fix * Patches by Tolunay Orkun, 17 Mar 2004: - Add support for bd->bi_iic_fast[] initialization via environment variable "i2cfast" (CONFIG_I2CFAST) - Add "i2cfast" u-boot environment variable support for csb272
2004-03-14* Patch by Tolunay Orkun, 5 Mar 2004:wdenk
Fix early board initialization for Cogent CSB272 board * Patch by Ed Okerson, 3 Mar 2004: fix CFI flash writes for little endian systems * Patch by Reinhard Meyer, 01 Mar 2004: generalize USB and IDE support for MPC5200 with according changes to IceCube.h and TOP5200.h add Am29LV256 256 MBit FLASH support for TOP5200 boards add info about USB and IDE to README
2004-02-23* Patch by Laurent Mohin, 10 Feb 2004:wdenk
Fix buffer overflow in common/usb.c * Patch by Tolunay Orkun, 10 Feb 2004: Add support for Cogent CSB272 board * Code cleanup
