Fixing the get_timer function to return time in miliseconds instead of
ticks. Also fixed PXA boards to use the conventional value of 1000 for
CONFIG_SYS_HZ.
Signed-off-by: Micha Kalfon <smichak.uv@gmail.com>
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command
rather than a generic "env" command, or anything else related to the
environment. So, let's make sure the define is named accordingly.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Explicitly add in default CONFIG_BOOTP_* options where cmd_confdefs.h
used to be included but CONFIG_BOOTP_MASK was not defined.
Remove lingering references to CFG_CMD_* symbols.
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards
- introduce two new configuration options instead:
CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL
- rename memsetup into lowlevel_init (function name and source files)
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c
* Patch by Anders Larsen, 17 Sep 2003:
Bring ARM memory layout in sync with the documentation:
stack and malloc-heap are now located _below_ the U-Boot code
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
- logdl
- csb226
- innokom
* Patch by Pantelis Antoniou, 25 Jun 2003:
update NetVia with V2 board support
- fix bug in BOOTP code (must use NetCopyIP)
- update of CSB226 port
- clear BSS segment on XScale
- added support for i2c_init_board() function
- update to the Innokom plattform
* Extend support for redundand environments for configurations where
environment size < sector size
- use watchdog to reset PXA250 systems
- added progress callbacks to (some of the) ARM code
- update for Cogent CSB226 board
* Add support for FPS860 board
seconds instead of ms.
* Patch by Robert Schwebel, 1 Nov 2002:
XScale related cleanup (affects all ARM boards)
* Cleanup of names, warnings and README.
