path: root/include/configs/crownbay.h
2017-08-01x86: Switch all boards to use DM SCSIBin Meng
After MMC is converted to DM, convert to use DM SCSI as well for all x86 boards and imply BLK for both MMC and SCSI drivers. CONFIG_SCSI_DEV_LIST is no longer used. Clean them up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-25Convert CONFIG_ARCH_EARLY_INIT_R to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ARCH_EARLY_INIT_R Signed-off-by: Simon Glass <sjg@chromium.org>
2016-12-29mmc: move some SDHCI related options to KconfigMasahiro Yamada
While I moved the options, I also renamed them so that they are all prefixed with MMC_SDHCI_. This commit was created in the following steps. [1] Rename with the following command find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_MMC_SDMA/CONFIG_MMC_SDHCI_SDMA/g s/CONFIG_BCM2835_SDHCI/CONFIG_MMC_SDHCI_BCM2835/g s/CONFIG_KONA_SDHCI/CONFIG_MMC_SDHCI_KONA/g s/CONFIG_MV_SDHCI/CONFIG_MMC_SDHCI_MV/g s/CONFIG_S5P_SDHCI/CONFIG_MMC_SDHCI_S5P/g s/CONFIG_SPEAR_SDHCI/CONFIG_MMC_SDHCI_SPEAR/g ' [2] create the Kconfig entries in drivers/mmc/Kconfig [3] Move the options by the following command tools/moveconfig.py -y MMC_SDHCI_SDMA MMC_SDHCI_BCM2835 \ MMC_SDHCI_KONA MMC_SDHCI_MV MMC_SDHCI_S5P MMC_SDHCI_SPEAR [4] Sort drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-29mmc: move CONFIG_SDHCI to Kconfig, renaming to CONFIG_MMC_SDHCIMasahiro Yamada
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI. My motivation for the rename is, ultimately, to make all the MMC options prefixed with MMC_ and SDHCI options with MMC_SDHCI_, like Linux. This commit was created as follows: [1] Rename the config option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g' [2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig [3] run "tools/moveconfig.py -y MMC_SDHCI" [4] add "depends on MMC_SDHCI" to existing SDHCI driver entries Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-12x86: Convert to use DM VESA video driverBin Meng
At present only chromebook boards are converted to DM video. Other x86 boards are still using the legacy cfb_console driver. This switches to use DM version drivers. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-05x86: tnc: Drop unprotect_spi_flash()Bin Meng
Unprotecting SPI flash is now handled in the SPI controller driver, via a call to the PCH driver. Drop the ad-hoc version. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-11-19x86: crownbay: Convert to use driver model keyboardBin Meng
Convert to use driver model keyboard on Intel Crown Bay. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-13x86: Remove CONFIG_SYS_EARLY_PCI_INITBin Meng
CONFIG_SYS_EARLY_PCI_INIT is not needed any more since with driver model, PCI enumeration is automatically triggered. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-13x86: crownbay: Remove unused PCI region address macrosBin Meng
These are leftover when converted to use driver model pci. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-21x86: Allow disabling IGD on Intel QueensbayBin Meng
Add a Kconfig option to disable the Integrated Graphics Device (IGD) so that it does not show in the PCI configuration space as a VGA disaplay controller. This gives a chance for U-Boot to run PCI/PCIe based graphics card's VGA BIOS and use that for the graphics console. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-09x86: crownbay: Enable CONFIG_PCH_GBEBin Meng
Now that we have converted the pch_gbe driver to driver moel, enable it on Intel Crown Bay board. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-09x86: crownbay: Convert to use CONFIG_DM_ETH for E1000Bin Meng
Since E1000 driver has been converted to driver model, enable it on Intel Crown Bay. But the Intel Topcliff GbE driver has not been converted to driver model yet, disable it for now. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-08-26x86: crownbay: Enable on-board SMSC superio keyboard controllerBin Meng
So far we only enabled one legacy serial port on the SMSC LPC47m superio chipset on Intel Crown Bay board. As the board also has dual PS/2 ports routed out, enable the keyboard controller which is i8042 compatible so that we can use PS/2 keyboard and mouse. In order to make PS/2 keyboard work with the VGA console, remove CONFIG_VGA_AS_SINGLE_DEVICE. To boot Linux kernel with PIC mode using PIRQ routing table, adjust the mask in the device tree to reserve irq12 which is used by PS/2 mouse. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-26x86: Enable CONFIG_PCI_CONFIG_HOST_BRIDGE for all boardsBin Meng
It looks that x86 chipset always contains a host bridge at pci b.d.f 0.0.0, so enable this for all boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05x86: Move CONFIG_X86_SERIAL to KconfigSimon Glass
Move this config option to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-14x86: crownbay: Enable graphics supportBin Meng
Enable graphics support on Intel Crown Bay board With the help of vgabios for Intel TunnelCreek IGD. Tested with an external LVDS panel connected to X4 connector and SDVO adapter connected to X9 connector on the board. Signed-off-by: Jian Luo <jian.luo4@boschrexroth.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: Set CONFIG_NR_DRAM_BANKS to 8 and move it to x86-common.hBin Meng
Some x86 boards set CONFIG_NR_DRAM_BANKS to 1, which causes incorrect DRAM size printed when booting from coreboot, like this: CPU: x86, vendor Intel, device 663h DRAM: 636 KiB Using default environment Change it to 8 which should be enough for both coreboot and bare cases, and move it to x86-common.h. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29x86: queensbay: Implement PIRQ routingBin Meng
Implement Intel Queensbay platform-specific PIRQ routing support. The chipset PIRQ routing setup is called in the arch_misc_init(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29x86: Move CONFIG_ENV_IS_IN_SPI_FLASH to x86-common.hBin Meng
Since all x86 boards use spi flash as its bootloader storage media, it makes sense to make CONFIG_ENV_IS_IN_SPI_FLASH a common option. So far only minnowmax board does not support it so undefine it in its board configuration file. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-24x86: crownbay: Enable saving environment in SPI flashBin Meng
Saving U-Boot's environment in SPI flash on Intel CrownBay board. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sg@chromium.org>
2015-03-24x86: crownbay: Enable Intel Topcliff GMAC supportBin Meng
Intel Crown Bay board has one ethernet port connected from Intel Topcliff PCH. Enable it in the board configuration. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2015-01-13x86: Move CONFIG_X86_RESET_VECTOR and CONFIG_SYS_X86_START16 to KconfigBin Meng
Convert CONFIG_X86_RESET_VECTOR and CONFIG_SYS_X86_START16 to Kconfig options so that we can remove them from board configuration file. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-18x86: Rename coreboot-serial to x86-serialBin Meng
2014-12-18x86: crownbay: Add SDHCI supportBin Meng
There are two standard SD card slots on the Crown Bay board, which are connected to the Topcliff PCH SDIO controllers. Enable the SDHC support so that we can use them. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-18x86: crownbay: Enable Intel E1000 NIC supportBin Meng
We don't have driver for the Intel Topcliff PCH Gigabit Ethernet controller for now, so enable the Intle E1000 NIC support, which can be plugged into any PCIe slot on the Crown Bay board. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-18x86: crownbay: Add SPI flash supportBin Meng
The Crown Bay board has an SST25VF016B flash connected to the Tunnel Creek processor SPI controller used as the BIOS media where U-Boot is stored. Enable this flash support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-18x86: Add crownbay defconfig and config.hBin Meng
