path: root/include/configs/cpuat91.h
2011-07-04cpuat91: use atmel_usartAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Eric Bénard <eric@eukrea.com>
2011-07-04arm920t/at91: use new clock.c featuresAndreas Bießmann
This patch enables the new clock features from arm920t/at91/clock.c. This is an required step to get at91rm9200_usart replaced by atmel_usart driver. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Jens Scharsig <js_at_ng@scharsoft.de> Cc: Eric Bénard <eric@eukrea.com>
2011-04-27cpuat91: fix board supportEric Benard
- fix board support following relocation changes - switch to boards.cfg - disable i2c to keep size under 128kiB (1 sector) Signed-off-by: Eric Bénard <eric@eukrea.com>
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-08-20cpuat91: update defaut environementEric Bénard
Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-08-20cpuat91: convert to new at91 soc architectureEric Bénard
convert the board to the new soc architecture update default config i2c upgrade taken from eb_cpux9k2.h & board/BuS/eb_cpux9k2/cpux9k2.c Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-07-12cpuat91: unbreak ethernetEric Bénard
* the following problems are met : config was set to use the new driver as a default but - RMII was not enabled for the new driver - the new driver didn't compile with RMII enabled - the new driver initialize a PHY at address O when the PHY of this board is at 1 thus we get "AT91 EMAC RMII: No PHY present" * to fix these problems, this patch : - enable RMII for the new driver - fix the wrong define used in the at91_emac.c - allow the config file to set a default phy address (and use 0 as a default as in the actual at91_emac.c driver) Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-02-12add new CONFIG_AT91_LEGACYJens Scharsig
* add's the new temporary CONFIG_AT91_LEGACY to all board configs This will need for backward compatiblity, while change the SoC access to c structures. If CONFIG_AT91_LEGACY is defined, the deprecated SoC is used. Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-01-31new at91_emac network driver (NET_MULTI api)Jens Scharsig
* add's at91_emac (AT91RM9200) network driver (NET_MULTI api) * enable driver with CONFIG_DRIVER_AT91EMAC * generic PHY initialization * modify AT91RM9200 boards to use NET_MULTI driver * the drivers has been tested with LXT971 Phy and DM9161 Phy at MII and RMII interface Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-18AT91 CPUAT91 Fix compiler warningEric Benard
This change fixes the compiler warning main.c: In function 'abortboot': main.c:122: warning: too few arguments for format Signed-off-by: Eric Benard <eric@eukrea.com> Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-10-13Add support for Eukrea CPUAT91 SBCTom Rix
CPUAT91 is built around Atmel's AT91RM9200 and has up to 16MB of NOR flash, up to 128MB of SDRAM, and includes a Micrel KS8721 PHY in RMII mode. Signed-off-by: Eric Benard <eric@eukrea.com> Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
