path: root/include/configs/cpu9260.h
2014-05-27at91: remove redundant AT91FAMILY definition in board config fileWu, Josh
Now the AT91FAMILY is already defined in the at91 SoC header. The at91 board config file will include the SoC header file. So we can remove the redundant AT91FAMILY definition in at91 board config files. Signed-off-by: Josh Wu <josh.wu@atmel.com> [rebase patch] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-09at91: nand: switch atmel_nand to generic GPIO APIAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Acked-by: Scott Wood <scottwood@freescale.com>
2013-12-01arm926ejs, at91: add common phy_reset functionHeiko Schocher
add common phy reset code into a common function. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Jens Scharsig <esw@bus-elektronik.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Stelian Pop <stelian@popies.net> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Eric Benard <eric@eukrea.com> Cc: Markus Hubig <mhubig@imko.de> Acked-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Tested-by: Bo Shen <voice.shen@atmel.com> Acked-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-04arm: atmel: get rid of too many ifdefferyBo Shen
Get rid of too many ifdeffery in usb ohci driver Add following two configuration for USB clock selecting - CONFIG_USB_ATMEL_CLK_SEL_PLLB: using PLLB as usb ohci input clock - CONFIG_USB_ATMEL_CLK_SEL_UPLL: using UPLL as usb ohci input clock Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-01-26NAND: remove NAND_MAX_CHIPS definitionsVladimir Zapolskiy
This change follows the change by Wolfgang Grandegger (commit 6c869637fef), which allows to remove useless NAND_MAX_CHIPS definitions in board config files. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-11-29Fix Stelian's email addressStelian Pop
Change my old email address which is no longer valid. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-06-21cpu9260/9G20: fix board supportEric Benard
Signed-off-by: Eric Bénard <eric@eukrea.com>
2011-04-27cpu9260: update board supportEric Benard
- update to new relocation code - switch to boards.cfg - get rid of LEGACY (still a little hack in .h to compile) - add nand boot configuration - boot tested for the following configurations : 9260 (64MB RAM & nor boot) 9260_nand (64MB RAM & nand boot) 9G20_128M (128MB RAM & nor boot) 9G20_nand_128M (128MB RAM & nand boot) (nor boot is using lowlevel init) Signed-off-by: Eric Bénard <eric@eukrea.com>
2010-03-07ARM change name of defines for AT91 arm926ejsAchim Ehrlich
Configuration defines should be preceeded with CONFIG_SYS_. Renamed some at91 specific defines to conform to this naming convention: AT91_CPU_NAME to CONFIG_SYS_AT91_CPU_NAME AT91_MAIN_CLOCK to CONFIG_SYS_AT91_MAIN_CLOCK Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
2010-02-12add a new AT91 GPIO driverJens Scharsig
* add a real AT91 GPIO driver instead of header inline code * resolve the mixing of port and pins * change board config files to use new driver * add macros to gpio to realize backward compatibility Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-02-12add new CONFIG_AT91_LEGACYJens Scharsig
* add's the new temporary CONFIG_AT91_LEGACY to all board configs This will need for backward compatiblity, while change the SoC access to c structures. If CONFIG_AT91_LEGACY is defined, the deprecated SoC is used. Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-10-18AT91 CPU9260 CPU9G20 Fix compile warningsEric Benard
This change fixes the compiler warning nand_util.c:45:2: warning: #warning Please define CONFIG_SYS_64BIT_VSPRINTF for correct output! Signed-off-by: Eric Benard <eric@eukrea.com> Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-10-13Add support for Eukrea CPU9260/CPU9G20 SBCTom Rix
these boards are built around Atmel's AT91SAM9260/9G20 and have up to 64MB of NOR flash, up to 128MB of SDRAM, up to 2GB of NAND and include a 10/100 Ethernet PHY in RMII mode. Signed-off-by: Eric Benard <eric@eukrea.com> Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
