And also reformat defconfigs using "make savedefconfig" rule.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some
config headers. This is also probably fixes am335x_baltos board.
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and
make all UDC controllers select USB_GADGET_DUALSPEED:
- add next options to Kconfig selecting USB_GADGET_DUALSPEED:
- USB_GADGET_ATMEL_USBA
- USB_GADGET_DWC2_OTG
- USB_DWC3
- CI_UDC
- make USB_MUSB_GADGET select USB_GADGET_DUALSPEED
While at it, make some related fixes:
- remove DUALSPEED from configs that don't enable gadget support:
- kwb.h
- tseries.h
- add missing USB_GADGET option to next configs:
- novena_defconfig
- pcm051_rev*_defconfig
- xfi3_defconfig
The description was borrowed from kernel. Definitions were added to
defconfig files in a way that "make savedefconfig" generates exactly
the same file as used defconfig.
Boards using 0 mA as CONFIG_USB_GADGET_VBUS_DRAW value were moved to use
2 mA (as minimal allowed by Kconfig).
The description was borrowed from kernel. "tristate" type was changed
to "bool" (I believe we don't support modules for u-boot yet, right?).
CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along
as well.
Definitions were added to defconfig files in a way that
"make savedefconfig" generates exactly the same file as used defconfig.
[trini: Add zynq_zc702 conversion]
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
add support for DFU on the corvus board.
- rename at91_spl_board_init into spl_board_init
- use SZ_1X defines for sizes
The mpddr.c depends on ATMEL_BASE_MPDDRC for the base address to configure the controller.
This cannot be used when there is more than one controller (i.e. AT91SAM9G45, AT91SAM9M10).
Signed-off-by: Erik van Luijk <evanluijk@interact.nl>
[remove 'new blank line at EOF']
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
them from include/configs.
move MACH_TYPE into defconfig
- corvus board fix problems with toshiba nand chips
on the corvus board problems with toshiba chips
Manufacturer ID: 0x98 Chip ID: 0xdc encounterd.
Solve this in the following way:
- set other nand timings
- enable CONFIG_SYS_NAND_READY_PIN
- correct the MACH_TYPE setting
replaces the at91bootstrap code with SPL code.
make the spl image with:
./tools/mkimage -T atmelimage -d spl/u-boot-spl.bin spl/boot.bin
this writes the length of the spl image into the 6th
execption vector. This is needed from the ROM bootloader.
Reviewed-by: Bo Shen <voice.shen@atmel.com>
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Bo Shen <voice.shen@atmel.com>
Now the AT91FAMILY is already defined in the at91 SoC header. The at91
board config file will include the SoC header file.
So we can remove the redundant AT91FAMILY definition in at91 board
config files.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
[rebase patch]
This commit removes platform CONFIG_SYS_HZ definition for the
remainders of part1 (commit cdb23792) and part2 (commit f232950f).
Cc: Rob Herring <rob.herring@calxeda.com>
enable support for the siemens AT91SAM9G20 based board corvus.
Signed-off-by: Boris Schmidt <boris.schmidt@siemens.com>
