path: root/include/configs/corvus.h
2015-01-19arm, at91: corvus board updatesHeiko Schocher
- corvus board fix problems with toshiba nand chips on the corvus board problems with toshiba chips Manufacturer ID: 0x98 Chip ID: 0xdc encounterd. Solve this in the following way: - set other nand timings - enable CONFIG_SYS_NAND_READY_PIN - correct the MACH_TYPE setting Signed-off-by: Heiko Schocher <hs@denx.de>
2014-11-17arm, spl, at91: add spl support for the corvus boardHeiko Schocher
replaces the at91bootstrap code with SPL code. make the spl image with: ./tools/mkimage -T atmelimage -d spl/u-boot-spl.bin spl/boot.bin this writes the length of the spl image into the 6th execption vector. This is needed from the ROM bootloader. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Bo Shen <voice.shen@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-10-10arm, at91: add generic board support for the taurus and corvus boardHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-05-27at91: remove redundant AT91FAMILY definition in board config fileWu, Josh
Now the AT91FAMILY is already defined in the at91 SoC header. The at91 board config file will include the SoC header file. So we can remove the redundant AT91FAMILY definition in at91 board config files. Signed-off-by: Josh Wu <josh.wu@atmel.com> [rebase patch] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-05-27corvus: remove unneeded CONFIG_AT91_LEGACYAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Heiko Schocher <hs@denx.de>
2014-02-19config: remove platform CONFIG_SYS_HZ definition part 3Masahiro Yamada
This commit removes platform CONFIG_SYS_HZ definition for the remainders of part1 (commit cdb23792) and part2 (commit f232950f). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Rob Herring <rob.herring@calxeda.com>
2013-12-09arm, at91: add siemens corvus boardHeiko Schocher
enable support for the siemens AT91SAM9G20 based board corvus. Signed-off-by: Boris Schmidt <boris.schmidt@siemens.com> Reviewed-by: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
