The code density of x86_64 is not wonderful. Increase the maximum boot
size and adjust the load address to cope.
Display the type of CPU (x86 or x86_64) when starting up.
This makes use of the existing device tree node to use driver model
for the serial console.
Convert over this driver, using device tree to pass in the required
information. The peripheral is still probed, just the number of GPIO banks
and their offsets is in the device tree (previously this was a table in
the driver).
Enable FIT support and the bootelf command. Also change the default load
address to somewhere other than the normal load address of the kernel,
to allow for decompression without overwriting the original file.
To get a display in U-Boot on link you must either build a coreboot that
always sets it up, or use Esc-Refresh-Power to reset the machine.
When we do have a display, it is nice to display the model at the top, so
enable this option.
We may as well use hush. The auto-complete option was incorrect so this was
not enabled. Also expand the command line size a little and go back to the
default prompt since "boot>" doesn't seem any more useful.
Add defines to enable the Chrome OS EC interface and set it up on init.
The dhcp option is required to get bootp to work on the Chromebook Pixel,
so enable it.
This option specifies the default Device Tree used for the run-time
configuration of U-Boot.
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Michal Simek <michal.simek@xilinx.com>
This commit moves:
CONFIG_OF_CONTROL
CONFIG_OF_SEPARATE
CONFIG_OF_EMBED
CONFIG_OF_HOSTFILE
Because these options are currently not supported for SPL,
the "Device Tree Control" menu does not appear in the SPL
configuration.
Note:
zynq-common.h should be adjusted so as not to change the
default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME.
Acked-by: Michal Simek <michal.simek@xilinx.com>
Guard the LOADMK functionality with config to provide
an option to enable or disable it.
Enable it for all platforms in mainline which enable CONFIG_CMD_FPGA.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years
ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should
care about this parameter or it should be gone completely.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
libata already has similar functions as implemented in the ahci code.
Refactor the code to use the libata variants and remove the dependency on
ata.h. Convert some defines to use the version from libata.h. Also, remove
some unnecessary memset's of bss data.
This is a step toward hopefully merging ahci.c and dw_ahsata.c which are
essentially the same driver.
Reviewed-by: Tom Rini <trini@ti.com>
[trini: Fixup common/cmd_io.c]
Add configs to enable tracing when it is needed.
The new name is more aligned with Linux kernel's naming of TPM driver.
Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org>
We don't use zlib and gzip but do use lzo, so enable this.
This is a convenient way of finding out where boottime is going. Enable
it for coreboot.
While we don't want PCAT timers for timing, we want timer 2 so that we can
still make a beep. Re-purpose the PCAT driver for this, and enable it in
coreboot.
This timer runs at a rate that can be calculated, well over 100MHz. It is
ideal for accurate timing and does not need interrupt servicing.
Tidy up some old broken and unneeded implementations at the same time.
To provide a consistent view of boot time, we use the same time
base as coreboot. Use the base timestamp supplied by coreboot
as U-Boot's base time.
Signed-off-by: Simon Glass <sjg@chromium.org>base
Since the ICH SPI controller uses PCI, we must ensure that PCI is available
before it is inited.
This fixes the current "ICH SPI: Cannot find device" message on boot.
This command is useful for measuring SPI flash load times and the like.
Enable gettime as well to obtain absolute time tick values.
Turn on SPI flash support and related commands.
Enable PCI EHCI, storage, keyboard and Ethernet for USB.
Make use of a device tree on coreboot boards, and set the default
to link.
Invert the polarity of this option to simplify the Makefile logic.
Acked-by: Gabe Black <gabeblack@chromium.org>
Enable the io command for x86 on coreboot.
The config is current broken. It compiles but does not boot because IDE is
enabled. Remove all IDE options, and enable SCSI instead.
Also add a working boot command and Linux bootargs, and enable command
line editing to make it easier to work with.
This allows u-boot to figure out the partitions of a chrome-os install.
Signed-off-by: Gabe Black <gabeblack@chromium.org>
Enable the display on coreboot, using CFB.
This helps us monitor boot progress and determine where U-Boot dies if
there are any problems.
Signed-off-by: Stefan Reinauer <reinauer@google.com>
Enable this option to support booting a zImage.
Coreboot uses this controller to implement GPIO access.
This option protects the printf() functions from overflow.
We want to support VGA, serial, USB keyboard and the Coreboot memory
console buffer.
Coreboot boards have an LPC TPM connected, so enable this.
Now that coreboot doesn't need the start16 code, remove it. We need
to remove the CONFIG_SYS_X86_RESET_VECTOR option from coreboot.h also.
Putting global data on the stack simplifies the init process (and makes it
slightly quicker). During the 'flash' stage of the init sequence, global
data is in the CAR stack. After SDRAM is initialised, global data is copied
from CAR to the SDRAM stack
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
Enable AHCI driver for Intel SATA devices.
Enable Coreboot and EXT4 Filesystems on the coreboot board.
Remove any notion of CONFIG_SERIAL_MULTI from board config files.
Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless
to specify this config option in the board config files. Therefore
remove it.
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Stefan Roese <sr@denx.de>
CONFIG_NET_MULTI is not used anymore, so remove it from board files.
Cc: Kumar Gala <kumar.gala@freescale.com>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Acked-by: Tom Rini <trini@ti.com>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Heiko Schocher <hs@denx.de>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Tested-by: Marek Vasut <marek.vasut@gmail.com>
Tested-by: Heiko Schocher <hs@denx.de>
Add a target for running u-boot as a coreboot payload in boards.cfg, a
board, CPU and a config. This is a skeleton implementation which always
reports the size of memory as 64 MB.
