path: root/include/configs/controlcenterdc.h
2018-01-22fs: fat: Drop CONFIG_SUPPORT_VFATTuomas Tynkkynen
fat.h unconditionally defines CONFIG_SUPPORT_VFAT (and has done since 2003), so as a result VFAT support is always enabled regardless of whether a board config defines it or not. Drop this unnecessary option. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2017-12-12ata: Migrate CONFIG_LIBATA to KconfigTuomas Tynkkynen
This symbol enables some library code used by various SATA drivers, so make this a non-user-visible symbol select'ed by the respective drivers, and let moveconfig handle the rest. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-12-12ata: Migrate CONFIG_SCSI_AHCI to KconfigTuomas Tynkkynen
And use 'imply' liberally. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-08-11Convert CONFIG_CMD_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SCSI Also update the Makefile to use CONFIG_CMD_SCSI instead of CONFIG_SCSI to enable the command, fixing an earlier error. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [trini: Rework to default y if SCSI, drop cl-som-am57x which did not use CMD_SCSI for real] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-05-22Kconfig: Drop CONFIG_CMD_ENVSimon Glass
This option is not used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-23arm: mvebu: Add gdsys ControlCenter-Compact boardDirk Eibach
The gdsys ControlCenter Digital board is based on a Marvell Armada 38x SOC. It boots from SPI-Flash but can be configured to boot from SD-card for factory programming and testing. On board peripherals include: - 2 x GbE - Xilinx Kintex-7 FPGA connected via PCIe - mSATA - USB3 host - Atmel TPM Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Mario Six <mario.six@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
