path: root/include/configs/controlcenterd.h
2016-08-05treewide: move CONFIG_PHYS_64BIT to KconfigMasahiro Yamada
We need to ensure that CONFIG_PHYS_64BIT is configured via Kconfig so that it is always available to the build system. Otherwise we can run into cases where we have inconsistent sizes of certain attributes. Ravi Babu reported offset mismatch of struct dwc3 across files since commit 95ebc253e6d4 ("types.h: move and redefine resource_size_t"). Since the commit, resource_addr_t points to phys_addr_t, whose size is dependent on CONFIG_PHYS_64BIT for ARM architecture. I tried my best to use "select" where possible (for example, ARMv8 architecture) because I think this kind of option is generally user- unconfigurable. However, I see some of PowerPC boards have 36BIT defconfigs as well as 32BIT ones. I moved CONFIG_PHYS_64BIT to the defconfigs for such boards. CONFIG_36BIT is no longer referenced, so all of the defines were removed from CONFIG_SYS_EXTRA_OPTIONS. Fixes: 95ebc253e6d4 ("types.h: move and redefine resource_size_t") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reported-by: Ravi Babu <ravibabu@ti.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-21powerpc/85xx: Increase fdt addressScott Wood
Loading the fdt at 0xc00000 fails if the uncompressed kernel image is greater than 12 MiB, which is quite common with modern kernels and multiplatform defconfigs. Move fdtaddr to 0x1e00000 which is just under the ramdiskaddr on most targets. Signed-off-by: Scott Wood <oss@buserror.net> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Andy Fleming <afleming@gmail.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-05-03include/configs: Numerous typo fixes: "controler" -> "controller".Robert P. J. Day
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-29common/board_f.c: change the macro name and remove it for PPC platformsGong Qianyu
For most PPC platforms, they will call the first get_clocks() in init_sequence_f[] as they define CONFIG_PPC. CONFIG_SYS_FSL_CLK is then defined to call the second get_clocks(), which should be redundant for PPC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-24common/board_f.c: modify the macro to use get_clocks() more commonGong Qianyu
get_clocks() should not be limited by ESDHC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-31tpm: Convert board config TPM options to KconfigSimon Glass
Convert all TPM options to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard <christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2014-09-24kconfig: move CONFIG_CMD_BOOTM to KconfigMasahiro Yamada
CONFIG_CMD_BOOTM is defined in config_cmd_defaults.h which is forcebly included from each board. So, the default value of "config CMD_BOOTM" should be "y". For some boards undefining it (bf506f-ezkit, controlcenterd_TRAILBLA, controlcenterd_TRAILBLAZER_DEVELOP, controlcenterd_TRAILBLAZER), "# CONFIG_CMD_BOOTM is not set" should be added to their defconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-07-25board: Add CONFIG_SYS_GENERIC_BOARD to all gdsys boardsDirk Eibach
Add the generic board infrastructure to all gdsys boards. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2014-07-07board: gdsys: Configure bridge on DP501 to support DDC onlyDirk Eibach
The I2C bridge on DP501 supports EDID, MCCS and HDCP by default. Allow EDID only to avoid I2C address conflicts. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-01-24powerpc: mpc85xx: move CONFIG_MPC85xx definition to CPU config.mkMasahiro Yamada
Define CONFIG_MPC85xx in arch/powerpc/cpu/mpc85xx/config.mk because all target boards with mpc85xx cpu define it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-16mpc85xx: Add gdsys ControlCenter Digital boardDirk Eibach
The gdsys ControlCenter Digital board is based on a Freescale P1022 QorIQ SOC. It boots from SPI-Flash but can be configured to boot from SD-card for factory programming and testing. On board peripherals include: - 2x GbE - Lattice ECP3 FPGA connected via PCIe - mSATA RAID1 - USB host - DisplayPort video output - Atmel TPM Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Signed-off-by: Andy Fleming <afleming@freescale.com>
