path: root/include/configs/comtrend_vr3032u.h
2017-05-10MIPS: add BMIPS Comtrend VR-3032u boardÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
