path: root/include/configs/comtrend_ct5361.h
2017-05-31MIPS: add BMIPS Comtrend CT-5361 boardÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
