This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
configs/bcm28155_ap_defconfig
configs/dra72_evm_defconfig
configs/dra74_evm_defconfig
configs/ma5d4evk_defconfig
And also reformat defconfigs using "make savedefconfig" rule.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some
config headers. This is also probably fixes am335x_baltos board.
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and
make all UDC controllers select USB_GADGET_DUALSPEED:
- add next options to Kconfig selecting USB_GADGET_DUALSPEED:
- USB_GADGET_ATMEL_USBA
- USB_GADGET_DWC2_OTG
- USB_DWC3
- CI_UDC
- make USB_MUSB_GADGET select USB_GADGET_DUALSPEED
While at it, make some related fixes:
- remove DUALSPEED from configs that don't enable gadget support:
- kwb.h
- tseries.h
- add missing USB_GADGET option to next configs:
- novena_defconfig
- pcm051_rev*_defconfig
- xfi3_defconfig
The description was borrowed from kernel. Definitions were added to
defconfig files in a way that "make savedefconfig" generates exactly
the same file as used defconfig.
Boards using 0 mA as CONFIG_USB_GADGET_VBUS_DRAW value were moved to use
2 mA (as minimal allowed by Kconfig).
The description was borrowed from kernel. "tristate" type was changed
to "bool" (I believe we don't support modules for u-boot yet, right?).
CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along
as well.
Definitions were added to defconfig files in a way that
"make savedefconfig" generates exactly the same file as used defconfig.
[trini: Add zynq_zc702 conversion]
Remove the legacy way of enabling GPIO, SPI and UART on Vybrid
based boards since these driver's now only supports DT mode.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Some armv7 targets are missing a cache line size declaration.
In preparation for "arm: cache: Implement cache range check for v7"
patch, add these declarations with the appropriate value for
the target's SoC or CPU.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
LPUART is seen on Freescale VF610 and QorIQ Layerscape devices.
Create a Kconfig option and move it to defconfig for all boards
that have this serial driver.
There are already Kconfig options for SPI drivers, but we
have not moved them from config.h to defconfig files. This
commit does this in a batch.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
For most PPC platforms, they will call the first get_clocks() in
init_sequence_f[] as they define CONFIG_PPC. CONFIG_SYS_FSL_CLK is
then defined to call the second get_clocks(), which should be
redundant for PPC.
Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
get_clocks() should not be limited by ESDHC.
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Remove spurious new line in configuration file.
Tested-by: Marek Vasut <marex@denx.de>
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
This introduces a coherent scheme for naming USB download gadget and functions
config options. The download USB gadget config option is moved to
CONFIG_USB_GADGET_DOWNLOAD for better consistency with other gadgets and each
function's config option is moved to a CONFIG_USB_FUNCTION_ prefix.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Tested-by: Lukasz Majewski <l.majewski@samsung.com>
Test HW: Odroid_XU3 (Exynos5422), trats (Exynos4210)
configs/tbs2910_defconfig
configs/tqma6q_mba6_mmc_defconfig
configs/tqma6q_mba6_spi_defconfig
configs/tqma6s_mba6_mmc_defconfig
configs/tqma6s_mba6_spi_defconfig
include/configs/mx6_common.h
Increase console IO buffer size to 1024 from the previous value of 256.
The previous value was too short for editing environment variables like
ubiboot from the console.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
them from include/configs.
Acked-by: Stefan Agner <stefan@agner.ch>
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
This changes enable ONFI detection. The Read ID command now allows
one address byte which is needed for ONFI detection. To read the
ONFI parameter page, the NAND_CMD_PARAM need to be supported. The
CMD code enables one command and one address byte along with reading
data from flash using R/B#, as specified by ONFI.
Signed-off-by: Stefan Agner <stefan@agner.ch>
This commit allows users to enable/disable the Freescale NFC
controller found in systems like Vybrid (VF610), MPC5125, MCF54418
or Kinetis K70 via Kconfig with more detailed help docs.
[scottwood: updated vf610twr_nand_defconfig]
Enable USB support on Toradex Colibri Vybrid Modules.
This adds initial support for Colibri VF50/VF61 based on Freescale
Vybrid SoC.
- CPU clocked at 396/500 MHz
- DDR3 at 396MHz
- for VF50, use PLL2 as memory clock (synchronous mode)
- for VF61, use PLL1 as memory clock (asynchronous mode)
- Console on UART0 (Colibri UART_A)
- Ethernet on FEC1
- PLL5 based RMII clocking (E.g. No external crystal)
- UART_A and UART_C I/O muxing
- Boot from NAND by default
Tested on Colibri VF50/VF61 booting using serial loader over UART.
