The distro bootscript uses kernel_image to get the file name of the kernel,
so change that variable name.
UBI boot has precedence in the default boot command. If one wants to boot from
SD with a working NAND installation stop in U-Boot and enter:
setenv fdtfile ${soc}-colibri-${fdt_board}.dtb && run distro_bootcmd
Replace usage of "/dev/mmcblk*p*" with a proper UUID of rootfs
partition. This fixes the issue, when MMC controllers are probed in
a different order in U-boot and Linux kernel.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Currently, Vybrid's sdboot variable tries to load the kernel from /boot
of the root partition (typically second partition when using the sdcard
image). However, since we moved to flash the kernel in a separate UBI
volume, we no longer deploy the kernel/device tree to /boot, hence
sdboot does not work in its current state.
Load the kernel and device tree from the first (typically FAT) partition
as customary on all Toradex modules.
While at it also change from rw to ro as e.g. systemd will re-mount the
root file system rw anyway after checking it.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
It turns out that OpenSSL calls undefined instructions to detect
ARM capabilities at runtime (via SIGILL handler). This leads to
stack traces e.g. when logging in using SSH:
[ 877.464442] sshd (613): undefined instruction: pc=76ee2da8
Disable undefined instruction events since it is used as an
autodetecion mechanism.
Let the kernel print some debug messages when a user program
crashes due to an exception.
Set fdtfile to represent the current board. This allows distribution
to load the correct device tree, which in the module case often
deviates from the common fallback ${soc}-${board}${boardver}.dtb...
Add support for distro boot. This is especially helpful for external
devices. There is a global boot command which scans a predefined
list of boot targets:
run distro_bootcmd
As well as direct boot commands such as:
run bootcmd_mmc0
run bootcmd_usb
run bootcmd_dhcp
Refer to doc/README.distro fo details.
While at it also re-order boot command macros as well as the
CONFIG_EXTRA_ENV_SETTINGS.
Use SZ_X{MK} macros from linux/sizes.h for include/configs/colibri_vf.h.
Migrate FEC, ESDHC, NFC and USB to driver model.
While at it also do no longer enable optional I2C clock in board file as
the generic clock code now handles this. Note for space reason and as
it is not required just for booting we do not enable I2C in U-Boot by
default.
While at it also update copyright period.
While commit 3e020f03e94f ("driver: misc: add MXC_OCOTP Kconfig entry")
introduced a Kconfig entry it did not actually migrate all
configurations to using it.
As CONFIG_MXC_OCOTP was in mx{6/7}_common.h enable it by default on
those architectures. Additionally, also enable it on ARCH_IMX8M and
ARCH_VF610 where all current members enabled it through their legacy
configuration header files.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Remove obsolete MMC/SD card environment configuration dating back to
un-fused samples times.
While at it also remove meanwhile spurious "USB Storage" comment.
Move CONFIG_USB_EHCI_VF to drivers/usb/host/Kconfig and update the one
and only user thereof being colibri_vf.
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_MTD_PARTITIONS
CONFIG_MTD_DEVICE
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Petr Vorel <petr.vorel@gmail.com>
Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig.
[trini: Re-run migration]
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
This commit moves USB_FUNCTION_MASS_STORAGE config to Kconfig.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
On Vybrid SoCs U-Boot gets loaded into GFX SRAM which is 512KiB.
Currently 32KiB is reserved for the IMX header. However, this is
not reflected in the size limit. In v2017.11-rc2 the actual size
limit (512KiB-32KiB) has been reached for Colibri VF61, which
lead to a successful build of U-Boot but not a working binary.
The IMX header is much smaller than 32KiB, typically around 1KiB.
Decrease the reserved size to 4KiB and specify the correct U-Boot
size limit. Apply this new base address and limit for all Vybrid
based boards.
Now that include/config_fallbacks.h define a sane fallback for
CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all
configurations that were using the default value.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Now that the fallback value of CONFIG_SYS_PBSIZE in
include/config_fallbacks.h has been adjusted, remove its definition
from a large number of board configuration files.
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
Migrate all remaining instances of CMD_NAND, CMD_NAND_TRIMFFS
CMD_NAND_LOCK_UNLOCK and CMD_NAND_TORTURE from the headers into the
defconfig files.
The above CONFIG options are in Kconfig, and now have correct depends and
inter-dependencies. Migrate these to configs/ from include/configs/. In the
case of CMD_UBIFS also change it to be a default y if CMD_UBI.
CONFIG_CMD_FUSE
Migrate the rest of the users of CONFIG_USB_EHCI_HCD over to Kconfig.
For a few SoCs, imply or default y this if USB is enabled. In some
cases we had not already migrated to CONFIG_USB so do that as well.
In order to be able to migrate the various SoC EHCI CONFIG options we
first need to finish the switch from CONFIG_USB_EHCI to
CONFIG_USB_EHCI_HCD.
CONFIG_CMD_BMP
[trini: Add depends on LCD || DM_VIDEO || VIDEO]
The Vybrid SoC family has the same display controller unit (DCU)
like the LS1021A SoC. This patch adds platform data, pinmux defines
and clock control to enable the driver for Toradex Colibri Vybrid
module.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
With d53ecad92f06 some unused interrupt related code was removed.
However all of these options are currently unused. Rather than migrate
some of these options to Kconfig we just remove the code in question.
The only related code changes here are that in some cases we use
CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename
and move the value local to the code in question.
Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi")
configs/bk4r1_defconfig
configs/colibri_vf_defconfig
configs/pcm052_defconfig
include/configs/pcm052.h
Move this in to Kconfig with a default of 115200.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
[trini: Run moveconfig.py, reword commit slightly]
Move Freescale/NXP Vybrid to a standard arch/board approach, similar
to what has been done to i.MX 6 earlier in commit 89ebc82137be ("ARM:
mx6: move to a standard arch/board approach").
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for
various reasons. We also have cases where we only build SPL in Thumb2 mode due
to size constraints and wish to build the rest of the system in ARM mode. So
in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to
control if we build everything or just SPL (or in theory, just U-Boot) in
Thumb2 mode.
Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC.
Let's create an entry for "config GENERIC_MMC" with "default MMC",
then convert all macro defines in headers to Kconfig. Almost all
of the defines will go away.
I see only two exceptions:
configs/blanche_defconfig
configs/sandbox_noblk_defconfig
They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something
might be wrong with these two boards, so should be checked later.
Anyway, this is the output of the moveconfig tool.
[1] create a config entry in drivers/mmc/Kconfig
[2] tools/moveconfig.py -r HEAD GENERIC_MMC
[3] manual clean-up of garbage comments in doc/README.* and
include/configs/*.h
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
CONFIG_ARCH_MISC_INIT
CONFIG_BOARD_EARLY_INIT_F
Signed-off-by: Jagan Teki <jagan@openedev.com>
Add option SYS_FSL_ERRATUM_ESDHC111, SYS_FSL_ERRATUM_ESDHC13,
SYS_FSL_ERRATUM_ESDHC135, SYS_FSL_ERRATUM_ESDHC_A001 to mmc Kconfig.
Move existing macros to related Kconfig.
Signed-off-by: York Sun <york.sun@nxp.com>
[trini: Migrate bk4r1]
Commit 7a777f6d6f35 ("mmc: Add generic Kconfig option") created
a Kconfig entry for this option without any actual moves, then
commit 44c798799f66 ("sunxi: Use Kconfig CONFIG_MMC") moved
instances only for SUNXI.
We generally do not like such partial moves. This kind of work
is automated by tools/moveconfig.py, so it is pretty easy to
complete this move.
I am adding "default ARM || PPC || SANDBOX" (suggested by Tom).
This shortens the configs and will ease new board porting.
[1] Edit Kconfig (remove the "depends on", add the "default",
copy the prompt and help message from Linux)
[2] Run 'tools/moveconfig.py -y -s -r HEAD MMC'
Migrate CONFIG_ARCH_USE_MEMSET/MEMCPY with this merge.
Move USE_ARCH_MEMCPY/MEMSET options to Kconfig.
Make it "default y" for the ARMv7 architecture and make it
depend on !ARM64 && !SPL.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
