Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Acked-by: Stefan Agner <stefan@agner.ch>
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
This changes enable ONFI detection. The Read ID command now allows
one address byte which is needed for ONFI detection. To read the
ONFI parameter page, the NAND_CMD_PARAM need to be supported. The
CMD code enables one command and one address byte along with reading
data from flash using R/B#, as specified by ONFI.
Signed-off-by: Stefan Agner <stefan@agner.ch>
This commit allows users to enable/disable the Freescale NFC
controller found in systems like Vybrid (VF610), MPC5125, MCF54418
or Kinetis K70 via Kconfig with more detailed help docs.
[scottwood: updated vf610twr_nand_defconfig]
Enable USB support on Toradex Colibri Vybrid Modules.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
This adds initial support for Colibri VF50/VF61 based on Freescale
Vybrid SoC.
- CPU clocked at 396/500 MHz
- DDR3 at 396MHz
- for VF50, use PLL2 as memory clock (synchronous mode)
- for VF61, use PLL1 as memory clock (asynchronous mode)
- Console on UART0 (Colibri UART_A)
- Ethernet on FEC1
- PLL5 based RMII clocking (E.g. No external crystal)
- UART_A and UART_C I/O muxing
- Boot from NAND by default
Tested on Colibri VF50/VF61 booting using serial loader over UART.
