path: root/include/configs/colibri_t30.h
2015-08-13apalis/colibri_t20/30: clean-upMarcel Ziswiler
Various clean-ups either in comments, order or spacing without any functional impact: - Add some comments in the device trees resp. reorder some parameters for consistency across all our modules. - Sort some include files alphabetically (while leaving common.h on top of course). - Streamline some comments in the configuration files and fix the spacing from using spaces to tabs. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-13apalis/colibri_t20/t30: increase tftp blocksizeMax Krummenacher
Enable CONFIG_IP_DEFRAG and set CONFIG_TFTP_BLOCKSIZE to 16384. This increases the tftp download speed considerably. While at it enable CONFIG_TFTP_TSIZE which limits the progress bar to fifty '#' independent of the downloaded file size. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-13apalis/colibri_t20/t30: integrate recovery mode detectionMarcel Ziswiler
Allow detecting whether or not U-Boot was launched through the recovery mode of the resp. NVIDIA SoC. Make use of a board specific arch_misc_init() and enable the same via CONFIG_ARCH_MISC_INIT configuration option. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-05configs: Remove CONFIG_SERIAL_MULTIStephen Warren
This config option isn't used anywhere at all. Remove all places that define/enable the option. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-03-04apalis/colibri_t30: add misc cmds increase buf sizes and max argsMarcel Ziswiler
In order to work with our downstream U-Boot environment and update scripts add support for the following miscellaneous commands: CONFIG_CMD_SETEXPR CONFIG_FAT_WRITE Increase the console I/O and print as well as argument buffer sizes: CONFIG_SYS_CBSIZE CONFIG_SYS_PBSIZE CONFIG_SYS_BARGSIZE Increase the maximum number of arguments allowed: CONFIG_SYS_MAXARGS Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-04ARM: tegra: move common config defines centrallyStephen Warren
All boards need CONFIG_BOARD_EARLY_INIT_F, and many actively need CONFIG_BOARD_LATE_INIT. Move both of these into tegra-common.h so that board config headers don't need to repeatedly define them. Later commits will add new code in board_late_init() which applies to all boards, so CONFIG_BOARD_LATE_INIT should be enabled for all Tegra boards. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-11dm: i2c: tegra: Convert to driver modelSimon Glass
This converts all Tegra boards over to use driver model for I2C. The driver is adjusted to use driver model and the following obsolete CONFIGs are removed: - CONFIG_SYS_I2C_INIT_BOARD - CONFIG_I2C_MULTI_BUS - CONFIG_SYS_MAX_I2C_BUS - CONFIG_SYS_I2C_SPEED - CONFIG_SYS_I2C This has been tested on: - trimslice (no I2C) - beaver - Jetson-TK1 It has not been tested on Tegra 114 as I don't have that board. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22tegra: colibri_t30: clean-up spurious new lineMarcel Ziswiler
Clean-up a spurious new line which got introduced resp. left behind by commit f1ef2b62339526df3b921bcfefd174ce76d4c624 kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfig Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-08-18ARM: tegra: add Colibri T30 board supportStefan Agner
This adds board support for the Toradex Colibri T30 module. Working functions: - SD card boot - eMMC environment and boot - USB host/USB client (on the dual role port) - Network (via ASIX USB) Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Tom Warren <twarren@nvidia.com>
