path: root/include/configs/cobra5272.h
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2010-03-24ColdFire: Cache update for all platformsTsiChung Liew
The CF will call cache functions in lib_m68/cache.c and the cache settings are defined in platform configuration file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-08-25unify {CONFIG_,}ENV_IS_EMBEDDEDMike Frysinger
Some boards have fallen out of sync by defining CONFIG_ENV_IS_EMBEDDED manually. While it is useful to have this available to the build system, let's do it automatically rather than forcing people to opt into it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-14Remove unwanted ';' at end of define.Selvamuthukumar
Currently this is not creating any problem. But it will result in compilation error when used as below. printf("CFG_SDRAM_CFG2 - %08x\n", CFG_SDRAM_CFG2); Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com> continuation of the theme based on git grep "^#define CFG_.*;$" include/ Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-04-13Add CONFIG_MII_INIT support to related boardsTsiChung Liew
Replace CONFIG_8xx and CONFIG_MCF532x to CONFIG_MII_INIT in cmd_init.c. Add CONFIG_MII_INIT to board configuration files that use mii_init() in cmd_init.c. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2007-08-16ColdFire: cobra5272 platform for MCF52x2 updateTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-07-10include/configs/[a-e]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various c* named board config files.Jon Loeliger
2005-01-09Patch by Florian Schlote, 08 Sep 2004:wdenk
Add support for SenTec-COBRA5272-board (Coldfire).
