path: root/include/configs/cmi_mpc5xx.h
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2010-11-275xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2007-09-16TQM8xx[LM]: Fix broken environment alignment.Wolfgang Denk
With recent toolchains, the environment sectors were no longer aligned to sector boundaries. The reason was a combination of two bugs: 1) common/environment.c assumed that CONFIG_TQM8xxL would be defined for all TQM8xxL and TQM8xxM boards. But "include/common.h", where this gets defined, is not included here (and cannot be included without causing lots of problems). Added a new #define CFG_USE_PPCENV for all boards which really want to put the environment is a ".ppcenv" section. 2) The linker scripts just include environment.o, silently assuming that the objects in that file are really in the order in which they are coded in the C file, i. e. "environment" first, then "redundand_environment", and "env_size" last. However, current toolchains (GCC-4.x) reorder the objects, causing the environment data not to start on a flash sector boundary: Instead of: we got: 40008000 T environment 40008000 T env_size 4000c000 T redundand_environment 40008004 T redundand_environment 40010000 T env_size 4000c004 T environment Note: this patch fixes just the first part, and cures the alignment problem by making sure that "env_size" gets placed correctly. However, we still have a potential issue because primary and redundant environment sectors are actually swapped, i. e. we have now: 40008000 T redundand_environment 4000c000 T environment 40010000 T env_size This shall be fixed in the next version. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-29Disable network support on cmi_mpc5xx boardWolfgang Denk
..because it caused compiler errors and there seems to be no board maintainer to take care of this. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-07-10include/configs/[a-e]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in mpc5xx board config files.Jon Loeliger
2003-03-31* Patch by Martin Winistoerfer, 23 Mar 2003wdenk
- Add port to MPC555/556 microcontrollers - Add support for cmi customer board with Intel 28F128J3A, 28F320J3A or 28F640J3A flash. * Patch by Rick Bronson, 28 Mar 2003: - fix common/cmd_nand.c
